GE Profile JTP18 Electric Single Oven Logo
A
Anonymous Posted on Aug 08, 2014
Reset button ge profile oven - GE Profile JTP18 Electric Single Oven
4 Related Answers
Cathy Shin
  • 3 Answers
  • Posted on Oct 03, 2008
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Anonymous
  • 106 Answers
  • Posted on Mar 24, 2009
SOURCE: GE True Temp Profile Oven, Locked Door Light stuck on
there should be some type of button that the door hits to turn it on and off
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Mar 28, 2009
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Mar 09, 2010
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
None of the control panel button work on my GE profile oven is there anyway to reset it
No you will need to replace the entire control panel to correct this, it is all one piece, buttons and board.
Nov 04, 2016 • GE Ovens
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • 0helpful
    Ge profile performance double oven. getting an F7
    F7 is a stuck keypad/button.
    Push all buttons at random several times each. This will sometimes un-stick a stuck button.
    If that does not work the keypad control will have to be replaced.
    Jan 16, 2010 • GE Ovens
    F7 Code on my GE Profile Oven
    3helpful
    My GE Oven heating element and timer clock went
    Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
    Try this link
    3helpful
    GE Profile Wall Oven Model JCKP16GS-1
    It sounds like this is a common occurance among GE ovens.
    Shut off the power at the box, then remove faceplate then remove the keypad.
    after doing so, remove it from connector, and clean pins with an eraser.
    Make sure the terminals are clean of debris, and check for a reset button on the back of the keypad.
    I hope this helped you out.
    Top GE Ovens Experts
    ZJ Limited
    ZJ Limited
    Paul Bade
    Are you a GE Oven Expert? Answer questions, earn points and help others
