Is there a function for me to listen to the radio using Panasonic Advanced Hybrid KX-T7730 phone? It is set in the office and is shared by all employees. I just want the phone at my seat connect to radio.
SOURCE: advanced hybrid system panasonic kx-t7730
how do i change my voice message on my answering machine??
SOURCE: how to set a radio inside the key phone under
You don't, it won't fit inside the cover :-)
A Panasonic phone system has a port labeled EXT MUSIC. You run a cable from your music source to the port and program Background Music in software. Most of the phones then let you press "1" if you only have one music source, or dial a code and choose music 1 or 2.
Carl
SOURCE: I'm using Panasonic KX-T7730. and
In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
Carl
