Question about Sony Car Audio & Video
Amp repair advice
I have Sony Xplod Amplifier XM-SD51X - Class D 1100W Mono Amplifier the surface mounted resistors burned up along with the chips I replaced the chips but don’t know what to replace the surface mounted resistors with can I use the color code resistors if so what color codes should I use?
Check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Posted on Jul 01, 2009
SOURCE:
Is my class d 800 watt amp brigeable
If it is a mono amp, it is already bridged internally.
Oct 13, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
How much should I pay for a used one?
For a class D amp from Sony at 1100W peak, I wouldn't pay more than $75 for a used one.
Feb 23, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
When my amp comes on the green light turns red after a few seconds and sometimes it just fades out compleatly. but all my conections are good. what should i do?
disconnect your speaker wires and see if it still does it. if it doesn't you either have a shorted speaker wire or bad speaker. if it still does, the amp is bad.
Jun 04, 2009 | Sony Xplod Amplifier XM-SD51X - Class D...
How do I fix kick start lockup on a Baja 70cc motorcycle
if the kick starter is stuck that means the piston is probably stuck. Locked up the bike, pull the head off and look at the cyl.
Apr 27, 2009 | Car Audio & Video
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp not putting out any sound
Check you pre amp RCAs and make sure they are holding a voltage...this is where the Amp takes that signal and amplifies it...without this connection the amp will not produce any power.
Jan 31, 2007 | Sony Xplod Amplifier XM-SD51X - Class D...
Car Audio & Video Logo
143 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
