LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
I have water leaking in my LG model number LMX25964SS French door freezer drawer help?
Imy freezer is frosting up so I pulled everything out and cleaned it. Found a layer of ice on the bottom. That explains the frost. I kept the door open and found that water is coming out the vents I think. I pulled the back and there is no frost and the drain pan is empty? What can I do now?
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on May 31, 2008
SOURCE: LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Anonymous
  • 706 Answers
  • Posted on Sep 15, 2008
SOURCE: Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Anonymous
  • 1136 Answers
  • Posted on Jun 05, 2009
SOURCE: the bottom of my lg french door bottom freezer
Hi, The defrost drain is plugged. UNPLUG the refrigerator. Remove the rear inside panel in the freezer section and locates the drain hole below the evaporator coils. You will have to melt the ice in the drain hole and flush it out with hot water.
I hope this helps you. Please let me know if I can assist you further.
Vic
Avi
  • 66 Answers
  • Posted on Jan 21, 2011
SOURCE: Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Avi
  • 66 Answers
  • Posted on Jan 29, 2011
SOURCE: water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
1helpful
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
2answers
How to clear out the drain tube on a kitcheaid refrigerator
Freezer has been leaking water at the bottom. I opened the drawer/door and removed the bins, there was a small amount of ice formed on the bottom at the back, I broke it away and poured a small bit of warm water in the black drain hole. the next day the bottom and rear are full of frozen ice and it is difficult to open the drawer/door to the freezer. Everything is covered with frost. Help!
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Top drawer of freezer seems to work but large bottom drawer not freezing even at -5degrees. Can this be fixed?
This problem seems to be two sided. A refrigerator defrost it is supposed to take the water from defrost down a pipe located behind the freezer rear wall to a pan below the refrigerator where there is a fan blowing warm air over the water to evaporate back into your home or business. If that drain is blocked your refrigerator will accumulate a large block of ice and frost behind the rear panel of freezer and temperatures will warm considerably in fresh food compartment and freezer. Here is one site I want you to read over=> Leaking Refrigerators Just What may Be Happening and here=> Leaking Refrigerators here is a link to a service manual=> LFX25960xx Service Manual Let me know if this service manual is close enough to your model number. At this point I am looking for air blockage behind the rear panel of freezer. If air is being blocked by ice and frost you can use a hair drier to help speed you up while melting ice. If drain is blocked use whatever you can to open the drain line mentions on the links I sent you to and let me know what is found, Thanks Sea Breeze
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
4answers
My freezer is frosting...there is snow all over
In my case with constant snow and frost build-up in my bottom drawer GE freezer, it was because the drawer never properly closed. As one user noted, "there is no adjustment." However, there are "catches" at the rear of the drawer glides and in my case one needed adjustment because it was preventing the drawer from remaining closed tightly. SEE PHOTOS. The photos show many items removed, but to make this repair, you only need a butter knife to pop out the black plastic catch mechanisms at the back end of the drawer glides, and only if you can see that the spring is not properly positioned. SEE PHOTOS
Ice build up on floor of freezer drawer
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
