Question about Polaroid TLA-01911C TV
No enciende ni el stanbay tv polaroid tla-01911c
Tenia inflado un condensador lo remplase pero sigue sin encender
SOURCE:
  • 5 Answers
SOURCE: how to disassemble polaroid TLA-01911C lcd tv
1) Take the foot off the stand and with a long philips screwdriver remove the single screw that is at the top of the leg (inside leg). Then with the tv facing down lift straight up on the leg.
2) remove the two screws comming from the back of the tv along the bottom edge.
3) With the tv face down on a soft surface ( towel, bedspread, ect).
4) Be carefull with this step it this tv gave me some difficulty and I am experianced with this proceedure. Too much pressure or forcing it too hard will break your case. The back of the tv has a lip which inserts into the face.The face has tabs that lock into slots in the lip of the back. Carefully pry between the face and back pannel (I used my thumbnail and a 1" plastic putty knife.) and slide along the seam until the locking tabs pop loose. Continue sliding your instrument along the seam until all tabs are loose.
5) The back of the tv lifts off of the face leaving all electronics in the face of the tv.
That gets you into the tv. what you do from there is up to you, Good luck;)
Posted on Mar 19, 2009
  • 19 Answers
SOURCE: Polaroid TLA-01911C TV - I seem to have the same
I had the same problem - replaced the capacitors which cleaned up the signal. Then I hear a "buzzing" from the CCFL lamps. Turns out the solder job on the CCFL's themselves was shoddy and corroded. No good CCFL Power trips the inverter and turns the lamps off. Resoldering the wire to the end of the CCFL's fixed the problem permanently.
Posted on Dec 08, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a polaroid TV model # TLA-01911C. It has
Check the power supply and the voltage feeding th baclight inverter board.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=TLA-01911C
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 12, 2010
bugoy31
  • 1238 Answers
SOURCE: not really a problem but.
Good day!!!
all you need to do is to get Philip screw driver and remove all screw that connected to the base of your TV after that you can freely remove that base...
Thanks for using fixya...
Posted on Aug 11, 2011
  • 1212 Answers
SOURCE: Donde puedo comprar un control
Ebay,
www.replacementremotes.com
www.partstore.com
www.shopjimmy.com/tvs/remote-controls
Por "universal" control remoto codigos
http://www.polaroid-tv.com/polaroid-lcd-tv/codes/
Posted on Dec 10, 2011
El tablero de un 99 alero no enciende y el carro tampoco lo trato de encender el carro y se queda prendido por 1o2 segundos y se apaga todo tiene corriente menos el tablero
tengo un alero 99 y no funcionan la cuatro agujas del tablero y tampoco enciende el carro bueno si enciende pero por unos segundo y se apaga espero me puedan ayudar gracias
Sep 20, 2013 | 1999 Oldsmobile Alero
Mi laptop intenta encender pero no lo logra, enciende todos los leds por unos 2 segundos y luego se apaga
Es possible que tiene un problema de conector de DC:
Los s?ntomas de un gato roto del poder
1. Si menea el cable de alimentaci?n o el conector de Adaptador de C.A. en la espalda del laptop, el poder DIRIGIO y carga de bater?a DIRIGIO comienzo a parpadear.
2. La bater?a no cargar? en el laptop.
3. El laptop corre bien de una bater?a cargado.
4. Con el Adaptador de C.A. conect? el laptop parece estar muerto. Ning?n poder DIRIGIO ni carga de bater?a DIRIGIO actividad.
5. El laptop enchufa al azar lejos sin cualquier advertencia.
Si su laptop es sin garant?a, entonces puede fijar el problema por gato acerca de-soldando de DC-EN en la tabla de sistema. Si es todav?a bajo garant?a, ser?a fijado en ninguna carga a usted.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 11, 2011 | HP Pavilion dv6748us Notebook
The tv turns on and off always. just started happening. can i fix it? maybe open it up , clean it out?
TIENES QUE ABRIRLO COM MUCHO CUIDADO ,SIN TOCAR NI ROSAR CON EL DESARMADOR NINGUN COMPONENTE AHORA CUANDO LO TENGAS SIN LA TAPA POSTERIOR USA UNA SOPLADORA PARA RETIRAR EL POLVO QUE SE HA ACUMULADO AHI YO TUBE EL MISMO PROBLEMA Y UN AMIGO TECNICO ME *** LA SOLUCION Y LO HICE CON EL Y QUEDO NUEVO SI CON ESA LIMPIEZA SIGE EL AUTO ENCENDIDO LLEVALO A UN TECNICO PORQ ES UN CONDENSADOR ,QUE POR DEMAS ESTA Q TE DE EL NUMERO PORQ SOLO DEBE HACERLO UN ESPECIALISTA ES UN POCO TRABAJOSO PORQ HAY QUE SACAR TODA LA GALLETA OSEA EL CIRDUITO INTEGRADO COMPLETO REVISAR LA CONDUCTIVIDAD Y ENCONTRAR EL CONDENSADOR O RESISTENCIA QUE SE HAYA QUEMADO REEMPLASARLO Y LSTO ESPERO TE HAYA SERVIDO Y PORFAVOR NO TRATES DE CAMBIAR NINGUN COMPONENTE DEL CIRCUITO PORQ PUEDES HACER TIERRA Y LOQ PUEDE SER UN SIMPLE REEMPLAZO DE ALGO SE CONVIRTA EN ALGO MAS GRAVE APARTE EL FLYBACK TIENE CARGA DE ALTISIMA POTENCIA PUDIENDOTE OCASIONAR LA MUERTE POR ESO MI CONSEJO ....SALUDOS
Jun 14, 2011 | RCA TruFlat 27F520T 27" TV
HOLA NECESITO EL TIEMPO DE UNA ISUZU RODEO 1995 4 CILINDROS. CUANDO LA PRENDO TIENE UN FALLO QUE HACE COMO UNA EXPLOSIONES EN EL MOTOR, Y ASI CORRE. SI TIENEN LA SOLUCION SE LOS VOY A AGRADECER...
Tengo una isuzu rodeo 1995, empezo a encender la luz de check engine y se me apagaba y no queria encender...luego encendio, a veces hace como si no tuviera gasolina pero a veces enciende y se apaga, la utilizo asi pero cuando enciende el check engine se queda sin corriente y se apaga por completo, le lleve a hacerle un chequeo y ni el tecnico encontro nada, me pueden ayudar con ese problema?
Nov 29, 2009 | 1993 Isuzu Amigo
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Ws-65869
Existen unos capacitores que con el tiempo fallan y te dan el sintoma que tienes en tu TV. Estos filtros o condensadores estan localizados en la placa DM (Modulo Digital)
Presione Aqui donde se encuentran instrucciones de como y donde se encuentran los filtros.
Las instrucciones estan en Ingles pero hay fotos tambien.
Aug 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Polaroid TLA-01911C TV Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
