Question about HP PhotoSmart 7350 InkJet Printer
Why does the photo tray not engage in hp 7350
Photo tray doesn't push all the way in.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Look for jammed paper of some other object that might have fallen into the machine.....
Posted on Aug 07, 2014
5 Suggested Answers
SOURCE:
kakee
  • 1269 Answers
SOURCE: hp 7960 printer
Make sure the paper try is properly attached. Try to unplug the power of your pinter and the USB cable for about 2-3 minutes. Restart your computer. Plug the USB and power to the printer then turn it back on.
Posted on Oct 04, 2008
SOURCE: photo tray is engaged and will not calibrate
hrew it in the trash and used my old one
Posted on Jun 28, 2009
  • 2841 Answers
SOURCE: the kodak gloss paper gets jammed in my hp
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Posted on Nov 24, 2009
wayneard
  • 1901 Answers
SOURCE: how do you get your hp 7350 to print iron ons
Hello, here are a couple things to check.
1) Make sure your ink levels are good. Are you using original HP ink? Do not use refills.
2) Use a higher resolution when you go to print. (Click on Preferences to change the resolution. Look for Print Quality and select a minimum of 1200 DPI.)
Hope this helps.
Thanks for using Fixya.
Posted on Dec 09, 2009
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Trying to print - got Warning message THe paper cassette is no set correctly. Check for any objects in the cassett of block the cassett path and insert correctly
This can also be caused when the upper cassette tray (for small paper stock / photo paper) becomes detached from the lower tray. There is a gear attached to the lower paper tray which handles movement of the upper paper tray. Make sure that moving this gear causes the upper paper tray to move. If it doesn't, then you need to snap the upper paper try on a little better.
Jun 26, 2011 | Epson Stylus Photo 810 InkJet Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
My photosmart 7150 prints half a page(vertical half) ! It worked fine before this. Help! thanks
Ok, I was having this same problem and the solution for me appears to lay in the fact that the "photo tray" was pushed in, signaling to the printer that it should print to the size specifications of a photo (approximately half the width of a standard letter page). I should also mention that with my problem, the printer would hang at every single print job--presumably to wait for you to input your photo paper--and that executing this fix solved the problem.
To fix this, I followed these instructions: SOLUTION:Follow the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray .
Sep 26, 2009 | HP PhotoSmart 7150 InkJet Printer
Photo Tray Problem
When nothing worked, I reexamined the trays, and there is a small plastic hook about half an inch long under the left side of the D7460 output tray. The tray below had a small hole. So I clicked the two together, and the printer started printing. Probably like many of you I had elevated the output tray as the printer spews onto the floor. Apparently it needs this connection. So much time lost....
Apr 11, 2009 | HP Photosmart D7460 Printer
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
We have a kodak5300 easyshare all-in-one-printer,the photo paper tray was stuck [it was pushed back to far ?] know i got the WHOLE tray out ,how do i put the phototray back in???? Sylvia
put the tray straight in and push the right hand side in first and there is a latch on the left push that and then push the left hand side of the tray in...........hope that works.....:)
Dec 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart D7360-Won't print from photo tray
You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
HP PhotoSmart 7350 InkJet Printer Logo
65 people viewed this question
Clive
Clive
Thomas F. Schneider
