AOC MON LED 19.5 E2070SWN - Flachbildschirm TFT/LCD Logo
A
Anonymous Posted on Aug 07, 2014
Aoc monitor instructions
HOW DO I ADJUST COLOR AND BRIGHTNESS TO MY AOC MON LED 19.5 E2070SWN?
Bob Sloan
Level 3:
  • AOC Master 2,013 Answers
  • Posted on Aug 07, 2014
Bob Sloan
AOC Master
Level 3:
Answers
2013
Questions
Helped
356405
Points
8519
5 Related Answers
Anonymous
  • 94 Answers
  • Posted on Oct 27, 2008
SOURCE: monitor
hi auntie
while the monitor is OFF press and hold the MENU key,switch ON the monitor while still holding the MENU key and voila it is unlocked
Hope this fixes you
Anonymous
  • 25 Answers
  • Posted on Dec 12, 2008
SOURCE: problem in my aoc monitor
pls replace control button 4no
Anonymous
  • 122 Answers
  • Posted on Feb 14, 2010
SOURCE: Where can I find driver for my AOC 912vwa-19 inc
go to aoc.com and download the driver from there
Anonymous
  • 4 Answers
  • Posted on Mar 01, 2010
SOURCE: AOC color monitor model 5En...during
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Anonymous
  • Posted on Sep 01, 2010
SOURCE: i have aoc v22+ led monitor. Its max. resolution
my aoc v22 led monitor osd function has been locked. how to unlock it?
Power led brightly on but no display on AOC S5G10
It is understood that your AOC monitor is not working, you had followed troubleshooting steps like connecting VGA and Power cable from monitor to computer and the monitor panel light is ON but still no display. You have tried connecting another monitor and it is working fine, so it is advised to contact AOC support to check if the monitor is under warranty and it can be replaced or repair. To help you do these, please follow the link given below:
http://us.aoc.com/aoc-technical-support/?page=contact-technical-support
GuruAid.com
Adjust brightness
The brightness can be changed by pressing the menu button on the monitor.
How do I use I-Menu to darken screen?
You will need to lower either the Brightness or Gamma should be under the Star with the black and white circle in the middle.
Use I-Menu to darken screen
http://us.aoc.com/support/documents/pdf/documents/370
AOC monitor too bright!!!
Sounds like its T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD is given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
6helpful
4answers
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 • AOC Monitor
2helpful
Screen is too bright. How do we turn down the brightness?
There should be a menu button on the monitor it self, which will give a list of options, one of which should be brightness.
Also, windows 7 has a built in brightness setting -- search for calibrate display color
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
