"countdown before snapshop" option suddenly became unselectable, unless resolution is set to 640x480 - it used to work perfectly few days ago
SOURCE: hi..i have a problem my cyberlink youcam..i can
Download a network camera software to make possible recognising a connection on the computer. if any damages are on the device would not function. The device could require driver updates.
SOURCE: i have been using cyberlink youcam for the past
Hey Meena
Nice to see you here.
I think you have problem in video chatting with your fallows? (Just kidding )
Follow that link for your solution
Cyber-link You cam troubleshooting tip
Don't Forget To Rate if you succeed ,only.
SOURCE: how can I connect Cyberlink youcam program into
Hey BC2000 ,
Nice to see you here,
Lets start with Skype description
What is Skype
"Skype is IM and Internet calling Platform. Its works with VoIP Technology."
How to call someone on Video using Skype?
Step-1 Check out your webcam .You have webcam device in your system and its active.
Step-2 Now Download Skype and add contacts on Skype.
Step-3
Click on particular contact then you can see two option for
communication- One is Video and Another is call(Green Buttons)
Thank For reading-
For further Assistance Click here
SOURCE: How do i get the camera working on me youcam cyberlink?
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
In Skype settings setup your webcam.
Cyberlink youcam dark image solution: 7 steps with snapshots to solve this issue...
http://notechheadaches.blogspot.in/
I had faced the same issue so made a bolgpost for it..
