To attach a computer to the internet, you will need to have an internet connection in your home.
Your Dell inspiron desktop does not have a wireless connection card in it, unless you ordered that with your purchase. Unlike laptops, which mostly do have a Wifi card in it, to be more mobile.
After subscribing you will probably get a router to connect to your ISP (Internet Service Provider) something like this, sometimes the antenna's are inside (the antenna is for wireless connections):http://www.dlink.com/-/media/images/Products/DIR/803/DIR803A1ImageHBack.png
In the yellow port comes the internet connection from the modem, in the ports 1,2,3 and 4 you can connect internet capable devices, so also a desktop computer.
Then to get your computer connecting to the router you need to attach a so-called patch cable http://www.computercablestore.com/Certified_Cat_6_Patch_Boo_Blue_catID2175.aspx
to the router and to your computer in the network port: Sometimes the ISP gives one added to the package when you get your router.
Normally after booting up the computer will find the network automatically, else call the helpdesk of your internet provider or ask a computer knowledgable person to help you.
This is a Fibre Glass Modem on the right and next to it a router (left), the router can connect to your computer.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Hi Tony Perez, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What do you want to hook it up to?
