Samsung Smart TV and surround sound speakers
Other answers did not mention the use of HDMI connection. This connection, is on the back of the samsung TV and is labeled ARC for Audio Return Channel. You need to connect this to the HDMI ARC channel on your Yamaha receiver. You will also need to use an HDMI cable version 1.4 in order for this to work. This connection will allow you to have sources connected to the receiver which will then be played on the TV with the audio routed to the amplifier in the receiver. You will need to use the Samsung Menu to turn off the internal speakers in the TV and also turn on Anynet which will allow digital control signals to be passed between the TV and the receiver. You will initially use your samsung remote to set the source (HDMI) you just connected and let Anynet open the connection. From there you can set up the surround sound provided you are using your TV tuner which can provide surround sound. Alternatively, if you are using a cable box, you should be able to use Toslink optical or coax digital for the audio into your receiver to capture the surround sound directly from the cable box. To do this, you will need to modify the audio output settings of the cable box from SPDIF out to Dolby Digital AC3, etc.
I hope this helps you to fully enjoy your system.
Generally you will connect the Digital audio or optical audio cable from TV to the input of Receiver. Then using the remote control of Receiver you will program the source for digital audio or optical audio as TV. I am assuming the speakers on the receiver are already connected and working. All you do is then turn on TV and turn on Receiver and select TV on Receiver. The TV audio will play through the receiver. Make sure the TV sound is in Mute.
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
SOURCE: connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
