SOURCE: How do I change my mailbox to an information mailbox?
Changing a mailbox from a subscriber mailbox to an information mailbox would require you to delete one in favor of the other but, if you want to temporarily disable the message taking ability you could login to the mailbox, press the admin key, press the greeting key, press the choose key, select alternate greeting, when you choose your alternate greeting mailbox youll be asked if your mailbox should accept messages press the chng key to toggle from yes to no. dont forget to record a alternate greeting for the mailbox.
hope that helps
SOURCE: Nortel 7310 voicemail will not reset
You dont have the EXT of mailbox 222 assigned to ext 222. Go under F983 press mbox press chg press 222 press ok press next it was say EXT: see what ext is assigned to put in 222 press change enter 222.
If it tell you that 222 is already assigned you have to find the mail box it is assigned to. Usually involves checking every Mbox starting with 221
Hope this helps.
SOURCE: I have a Nortel 7316. I have tried an incorrect
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
SOURCE: Nortel T7316E callpilot voicemail is
Hello.
From FixYa Support:
How to Change a Mailbox Password
1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Hope this helps.
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
