Computers & Internet Logo
g
gerd rasta Posted on Aug 06, 2014
How to upgrade the cpu of my acer travelmate?
The speed of the notebook is only half of what it should be - 843,7 MHz rather than 1700 MHz. Rather than just replace it, could I upgrade to a faster CPU - say 2.6 GHz? Gerhard
5 Related Answers
Anonymous
  • 1124 Answers
  • Posted on Oct 13, 2008
SOURCE: cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Anonymous
  • 1179 Answers
  • Posted on Jun 01, 2009
SOURCE: CPU compatability
It is not compatible. If your fsb is 533mhz then any replacement cpu would need to be a 533mhz fsb chip. This is unless your motherboard supports different fsb's. You will need to check your manual or the manufacturers website to see what cpu's your system supports. Hope this helps.
Anonymous
  • 167 Answers
  • Posted on Sep 02, 2009
SOURCE: Acer 5100 / AMD Turion 64 MK36 clock speed at 797 Mhz.
http://gd.panam.acer.com/home/ download and install e-power management then you should have all the options to change speed and other. i have 2 of these 5100 notebooks-and try the other apps on the link i put for you. if i can help further reply. also see the driver section, you may need some of those as well! good luck and be well!
Anonymous
  • 2567 Answers
  • Posted on Nov 04, 2009
SOURCE: Can you do a cpu upgrade on Acer Travelmate
The following CPUs are supported by the Acer TravelMate 2480:
Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
KingDWS
Dave King
  • 1606 Answers
  • Posted on Apr 12, 2010
SOURCE: Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Testimonial: "Thanks for the quick response. I was afraid that might be the answer but I appreciate the confirmation."
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
2helpful
I have acer aspire 4736z, can I upgrade the processor to 3.2 Ghz?
Please note that CPU upgrades in notebooks/laptops/netbooks are highly problematic because they depend on often uncertain motherboard specifications (different notebook models bearing the same series number in your question can have different internal and external specification and be based on different motherboards).
The most serious problem you face is that CPU upgrades in laptops/notebooks/netbooks inevitably require near complete disassembly and the correct reassembly of the computer. Inevitably, this type of work is best done by an experienced professional, trained for and capable of performing a warrantied repair. Understandably, the associated labor costs will be on the high side.
Also, upgrading the CPU requires the user to first risk expenditure on an item that cannot be returned to the seller or supplier if later found to be incompatible but could still be a potentially expensive replacement product, without being absolutely certain that is compatible with the motherboard for which it is intended.
So you will need to do extensive research on the specification of the precise motherboard of the precise model of your notebook. To do this, you will need the full, long, specific model number plus also the Serial Number (S/N) and Part Number (P/N) of the computer that are usually printed on a label underneath the computer. From these, you should obtain the P/N of the motherboard, then navigate to the support and product information pages of the motherboard manufacturer's website to verify the CPU compatibility specifications of the motherboard and then proceed from there.
Intel Pentium Mobile processor T4200 (1 MB L2 cache, 2 GHz, 800 MHz FSB, 35 W), or T3400 (1 MB L2 Cache, 2.16 GHz, 667 MHz FSB, 35 W), supporting Intel 64 architecture
Your notebook features the above Central Processing Unit (CPU) in its standard specification, according to Acer. This CPU is commonly referred to as a Dual Core / Intel Pentium M / 2.2GHz / 64 Bit Processor. This type and Model of Processor is outdated and the upgrade options available to you are limited.
The indications are that your best course of action would be to back up any important data stored on this notebook's Hard Disk Drive (HDD), restore the notebook to Factory Settings, sell it on eBay or CraigsList or any similar website popular, in your geographical location, for the buying and selling of Used Consumer Goods and then put any sale income raised towards a new, state-of-the-art notebook capable of performing the function(s) in which the current notebook is disappointing you and steering you towards radical thoughts such as CPU upgrades.
At the very least, consider several or all of the far easier, far cheaper and far less labor-intensive and labor-expensive upgrade options to improve the power, speed and performance of this notebook before contemplating a CPU Upgrade, such as, a Maximum Capacity RAM Upgrade, an Operating System (O/S) Upgrade, upgrading to a higher performance, higher Spin Speed and/or higher capacity HDD or newer technology Solid State Drive (SSD).
Your full notebook specification and CPU Upgrade Options can be found on the support pages of the official Acer and Intel websites below:
http://support.acer.com/acerpanam/notebook/2010/acer/aspire/aspire4736z/aspire4736zsp2.shtml
http://www.intel.com/en_uk/consumer/products/processors/compare-processors.htm?fam=corei5
1helpful
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Which is the fastest cpu i can mount on my 2.6 ghz celeron based acer travelmate 244lc notebook now? Is there any fastest celeron compatible now? Thanks in advance anyway. Mario
2.6 Ghz is pretty fast already. If your computer is running your programs slow, you can upgrade your RAM to 2GB; this would speed it up allot.
2helpful
Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
4helpful
2answers
Need to speed up my Acer Travelmate 2410
According to your describe, your slow TravelMate laptop can caused by various hidden Windows errors. Those problems firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden! To quickly fix the problem, see resolution here: http://www.speedupacer.com/ Should help you out, good luck!
Processor upgrade for tavelmate 212txv
most of the models you posted only came with a Celeron 800 MHz cpu, (you can confirm this by r clicking on my computer and going to general tab) it will not support more than a 900 speed cpu if so
Acer aspire 5520-5865
Up to 2 GB of DDR2 667 MHz memory, upgradeable to 4 GB3 using two soDIMM modules (dual-channel support)
for your reference
http://global.acer.com/products/notebook/spec/Aspire.pdf
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
