Question about Frigidaire Affinity Series FASE7073LA Electric Dryer
Error E52 on frigidaire affinity
Error says E52 Motor. Dryer sets up but won't start. Goes to pause.
  • Official Brand Answer
  • 2,267 Answers
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Posted on Aug 13, 2014
6ya staff
SOURCE:
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 09, 2009
Anonymous
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
seth adams
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: my affinity frigidaire dryer keeps flashing an E9E error code
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Posted on Sep 27, 2010
Brandon
SOURCE: error code on a Frigidaire affinity dryer E64
Heating element wire malfunction.
Posted on Dec 18, 2011
When i try turn my frigidaire affinity dryer on it buzzes and goes to pause
Good Morning friend, thank you for your post!
From the information you have provided your Frigidaire dryer is buzzing and goes on pause when you attempt to turn it on. This could be a possible issue with your door latch, door strike, or control panel. If you dryer shows pause that means there is an interruption within your cycle. I would advise to look over your door latch and strike to see if there is any apparent damage to either component. If both components appear to be working properly I would advise to have a technician come out to review your control panel. I hope this information has been helpful to some degree. -Matt
Feb 17, 2015 | Frigidaire Dryers
How to fix so it turns on and drys instead of humming and Pausing
If the dryer is I humming but the drum is not turning then the motor is turning but the belt is not attached, it is probably broken and needs a new belt. if your belt is intact then your motor or start capacitor is bad.
Aug 09, 2014 | Electrolux Frigidaire Affinity AGQ8700FE...
What does E52 mean and how do i fix it
Good Morning blanchedogskin, I am happy to assist you!
An error code E52 typically relates to the speed control board or the motor itself. An experienced service technician would test these parts by measuring the resistance of the motor to distinguish exactly which part it is. This is not a typical do-it-yourself job. Personally, I would recommend reaching out to a qualified appliance repair person who will be best able to pinpoint the exact problem causing the error code. I hope this information helps to some degree.
Sep 17, 2013 | Frigidaire Affinity ATF7000E Front Load...
My front loader flashes E52 call for service
Hello willkie6 - An error code E52 typically relates to the speed control board or the motor itself. An experienced service technician would test these parts by measuring the resistance of the motor to distinguish exactly which part it is. This is not a typical do-it-yourself job. Personally, I would recommend reaching out to a qualified appliance repair person who will be best able to pinpoint the exact problem causing the error code. I hope this information helps to some degree.
Apr 15, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Error code 52, Dryer won't start
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
Oct 15, 2012 | Dryers
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity Washing Machine, 3 months old, pauses during cycle. Does not give any error code. Have tried different cycles, eventually it will run the cycle. Doesn't happen with every cycle, yet. Switches...
Did you figure out this problem? I think these machines are JUNK! We purchased our first Frigidaire Affinity in April 2010 & by September it started ripping our clothes apart. Not every cycle. At first we thought it was the dryer but nope - it was the washer. Something to do with the drum. We had it replaced in October 2010. Then after the truck dropped off the replacement, I tried doing my first load of laundry. It lite up & did nothing. Something to do with the motor. Again, we had a 3rd machine replacement. I wanted to give up, get my money back & go buy something else but I wanted it to match my dryer so I was kinda stuck. Our 3rd machine is now going to pause constantly during a cycle. I've read up on it & tried various things such as less soap, checking the drain etc. & nothing has changed this problem. I'm calling the store on Monday & demanding my money back & they can take back the dryer too. I have a feeling this might be a bit of a fight but I am disappointed with the results of this machine. We've lost about $100+ in clothing from the first machine, plus all the down time in all 3 of these machines not working & having to worry about going to do laundry elsewhere.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Series FASE7073LA Electric Dryer Logo
1,349 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
