Question about Kohler Command Pro OHV Horizontal Engine with Electric Start 25 HP,
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at next?
    Scholar:
  • 151 Answers
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Posted on Aug 06, 2014
4 Suggested Answers
SOURCE:
  • 5603 Answers
SOURCE: kohler 19 hp runs then backfires and stalls when heated up
Check that the keyway for the flywheel to the crankshaft hasn't sheared. This is a common problem that throws timing very far off causing backfire and no-starts.
Posted on Nov 02, 2009
  • 909 Answers
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
SOURCE: Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Posted on Jun 11, 2011
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
Sears GT 5000 garden tractor with Kohler 26 HP Courage engine. It won't start when it gets hot. It turns over, and sometimes just barely runs for a few seconds, but then dies. Choking it a little...
check spark plug sounds it s heating up to much make sure of oil level and if it has been sitting a while dump the gas in it and fill it with new and buy some sea foam and add a little to the gas
Jul 19, 2017 | Craftsman GT 5000 26 HP54" Garden Tractor...
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Mar 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Brother's Craftsman 22.5hp Kohler engine starts and runs for 10 mins. Ans shuts off. Will not restart.
Kohkler engine 22.5 hp will not restart in the morning,unless you shot some start fuild in the air cleaner
May 20, 2010 | Garden
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler Command Pro OHV Horizontal Engine with Electric Start 25 HP, Logo
409 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
