The button became loose but still worked, now no longer works. Have pulled of button - all seems ok, can turn white stem by hand, but just spins freely. Does oven need to be taken apart to fix or is this a component thing?
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Hello- The motor has a plastic gear on the shaft that turns glass tray. These can crack or slip off the shaft and not engage the slots on tray. Check to see if gear is cracked or stripped. It may just be loose. Anyway, this part is less than 10$, so replace if it's bad. Let me know if this solves the problem. Have more info if needed- Thanks- Ed
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
I'm assuming you are speaking of the line circuit breaker to the stove. If that is the case and there are ** other problems that you k**w of, it is possible that the breaker has gone bad....they do. Get the same brand and rating as you had originally installed. Cut your main feed and open the terminal panel and remove and replace the unit. Restart main feed and set breaker on. If you continue to have issues, check all wiring to your stove...a loose wire or corroded contact point may be a second issue.
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
