Canon PowerShot S2 IS Digital Camera Logo
A
Anonymous Posted on Aug 05, 2014
Formatting a new memory card - Canon PowerShot S2 IS Digital Camera
My nikon coolpix p2 camera says this memory card cannot be used, but it is a new memory card.
Have you formatted the memory card? When you buy a new memory card, you must go in your camera's menu and find the "format memory" selection and perform the format function. Once formatted by your camera, it should work.
2answers
When i insert my memory card into my brand new CASIO EX-55O/0 camera,a message comes up and says "card error"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (of which your camera was made before SDHC. You can only use 2GB or less cards). Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
2answers
I am unable to format my memory card? i have purchased new sandisk 2GB micro sd memory card,but in few days this problem will occur
We Wish You a Happy New year.
Right Click on the Memory card and check for properties and see, if it is showing 1.85 gb then you need not format or try to format in FAT32 if you are using NTFS.
Hope this helps you. Cheers!!!
2helpful
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
3helpful
3answers
How to i format my memory card for nokia 7373, its a new memory card, but when incerted it says, memeory card not formatted.
Just goto Menu -> tools -> memory
1. select Memory Icon.
2. Press Options
3. Select Format Memory card
4. Thats all.. your memory card will be formatted and ready to use.
I hope this solves your problem.
Thanks
Put new memory card in camera but has formatting problem. When memory card is put in it says the new memory card requires formatting. When I continue it states that formatting will delete everything in...
New batteries first!! Make sure they are "GOOD"
May have a bad or incompatible card.
Will you camera take pictures without a card in it?
If yes, you have a bad or incompatible card.
Try another card
Here is all the information you'll need to solve this:
Read it.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=8814&product=EKN031714
1helpful
My memory card has bad format should i get a new one
If you have a card reader try to format it via your pc that may help to recover your card. Else you have to purchase new one. Best of luck.
4helpful
2answers
Foramtting scandisk
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
