Will not spin. Drum just sits there and groans. No clothes in the drum. In diagnostic mode the error code is IF82. In run mode the error code is LE. Can find nothing on code IF82.
SOURCE: LG 2277 Spinning intermittently "growling"
Followup: (of techwannabe)
After researching a bit further it was worth the investment to replace the sensor assembly and see if this would fix the issue. Viola! runs like a champ. The part was located locally for a mere $ 25.00 and with a few tools, strength of a gorilla to move the machine I repaired it. Yes a mother of four can complete the job! The unit works beautifully.........................
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
SOURCE: LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
SOURCE: LG Tromm WM2075CW will not spin. I've done
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
SOURCE: LG TROMM front load washer - the drum won't spin,
My Tromm washer has LE Error code I have restarted unplugged and restarted same error code keeps coming up. What does this mean?
