I am using the single line input from my receiver to my sub. The SUB from my other system works when it is plugged into this same line so I am pretty sure it is the SONY sub that is not working.
With subs, it's either
You've ruled out most of this because another sub works in its place. So what's left is either sub settings, or a busted sub.
The sub settings for testing should be: Crossover frequency - Max; Volume - Mid; Phase - Normal.
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay or not.
Most subs auto sense a signal. So if the Sony isn't doing that then there's the problem. Given that these are very much a budget sub, I'd be inclined to have a look for something simple such as a broken solder joint or bulging capacitor. If it's anything more indepth then the cost to repair will outweigh the value of a replacement.
SOURCE: i just go a sony sa-wm20 sub woofer
Um, its hard to understand you, but to my understanding you don't know which is positive and which is negative... Striped= Positive, bold= Negative, or Red= Positive, black =Negative. Lastly + positive - negative
SOURCE: I have a Yamaha sub woofer model NX-SW150 that was
Where does the 1/8 3.5mm mono jack get plugged into on the receiver? The RCA subwoofer output is already taken.
