MODEL NUMBER PLES389ECB
Hello Friend, this is Z. I am happy to assist you!
If you are getting an error code F30 on your Frigidaire range, it usually indicates an issue with a faulty sensor probe or a wiring harness between the sensor probe and EOC (Electronic Oven Control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC of your range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
SOURCE: I have a Frigidaire Gallery wall oven, existing in
Have you turned off the house breaker to the unit to "reset" it? Leave it off for 2 min, turn it back on and see what happens. You'll need to reset the clock to use the oven, but hopefully it will allow you to open the door. Let us know if it works and we'll dig deeper.
SOURCE: How do I find the part number for replacing control board for GE?
WB27T10290
I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
SOURCE: My Oven is displaying a
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
