any generic replacement CMOS battery with the same specifications and size measurement as the original battery will do, I am not to familiar with the battery used on your laptop, for it may be installed with retaining clips, it may be soldered to the main board, or via sockets with wires, if you are not to savvy with electronics soldering , have someone who knows how , to do it for you. Replacing cmos battery is actually easy once you have secured the replacement part. refer to your computer manual for the location of the cmos battery on your laptop.
Asus motherboards usually use a lithium CR2032 battery for CMOS. Also, on the top of the old CMOS battery you took out there should be the exact battery type engraved on the surface.
Batteries Plus in Wichita, KS has a good online store for purchasing your replacement battery.
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOShttp://www.youtube.com/watch?v=P_cxAireIsw
Removing the CMOS battery for 15 mins will reset the CMOS. The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Assuming you know how to get into your computer and identify the CMOS battery, you just need a pair of tweezers or similar to remove the battery. Once it has removed, take it into a drug store or pharmacy and find the exact same battery, and replace it in the motherboard. If you can't identify the CMOS battery, please let me know and I can help you with that.
Computer CMOS informationCMOS is an on-board semiconductor chip powered by a CMOS battery inside IBM compatible computers that stores information such as the system time
How to replace the CMOS battery.
Information about why time may be lost or decreasing rapidly and how to replace your computer cmos battery
Computer Battery Help
The first type of battery is the backup battery, which is commonly referred to as the "CMOS battery".
