HP Pavilion a6838f Desktop PC  Logo
A
Anonymous Posted on Aug 05, 2014
Create password recovery disk - HP Pavilion a6838f Desktop PC
Bob Sloan
Level 3:
  • HP Master 2,013 Answers
  • Posted on Aug 05, 2014
Bob Sloan
HP Master
Level 3:
Answers
2013
Questions
Helped
356599
Points
8519
If you forgot your BIOS password. see this... http://www.wikihow.com/Break-a-BIOS-Password
If you forgot your windows Account Login password, the following page is a good description of your choices... http://pcsupport.about.com/od/tipstricks/tp/find-lost-windows-passwords.htm
Also, check out... http://ophcrack.sourceforge.net/
1helpful
Creating recovery disks for compaq sr1430nx
Well, I use Windows Password Reset to create password reset disk.
Follow my steps:
Step1:Download and install Windows Password Reset .
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove Windows Password.
Besides, Windows Password Recovery Tool also great to create reset disk.
tip
How to Create a Password Reset Disk in Windows 7/Vista/XP?
Forgetting Windows password occurs more often than the users would like to think. So if you haven't created a password reset disk for your user accounts, it's time for you to take action. A password reset disk enables you to reset Windows password if your Windows password is forgotten. If you have no idea, just look at the following instructions.
Windows 7/Vista Password Reset Disk
If you are Windows 7/Vista user, you can create a password reset disk to reset Windows password as follows. Just 6 steps:
1. Enter Create a password reset disk in the Start search box.
2. Press Enter to pop up the Forgotten Password Wizard.
3. Insert a USB flash drive and click Next on the Forgotten Password Wizard.
4. Select the right device store the password information of the use account which you are logged on.
5. Enter the current user account password.
6. Wait while wizard creates the password reset disk. Click Next when it 100% finishes and click Finish to exit.
Windows XP Password Reset Disk
If you still use Windows XP, just take the following steps for reference to create a password reset disk to in case of the need of Windows password recovery. Just 4 steps:
1. Click Start > Control Panel > User Accounts.
2. Select the target user account and click Prevent a forgotten password on the left pane. The Forgotten Password Wizard will appear.
4. Follow the wizard to create a password reset disk.
Windows Password Reset Disk Tips
1. The created password reset disk should be kept in a safe place as anyone can use it to reset Windows password without any limitations.
2. When you enter a wrong Windows password, the Password Reset link will appear under the password box. You can simply click the link to start Windows password recovery with your created password reset disk.
3. If you forgot Windows password without such a disk, you can reset Windows password by a Windows password recovery tool like Windows Login Recovery.
on Jan 06, 2011 • Computers & Internet
tip
Top 4 Options to Reset Windows Password
Forgot Windows password? Don't feel frustrated or annoyed. Windows has some handy features that allow you to recover or <a href="http://www.windowsloginrecovery.com/reset-windows-password.html">reset Windows password</a> on your own, for whatever reason you cannot gain access to your user account. Below are listed 4 of them. These <a href="http://www.windowsloginrecovery.com/reset-windows-password.html">Windows password reset</a> methods will work in all versions of Windows like Windows 7, Vista and XP.<br /><br />Option 1: Windows Password Hint<br /><br />Whenever you create or change Windows password, there will be an opportunity to type a password hint to help you remember the password. When you enter a wrong password in the Windows logon screen, the password hint will be displayed to remind you of how you made up your password (if you have created one). This is the easiest method to recover a lost password in Windows as far as I know. To in case that others will take advantage of the password hint, please note it should be vague enough so that nobody else can guess your password, but clear enough that it will remind you of your password.<br /><br />Option 2: Windows Password Reset Disk<br /><br />This is an easy and effective method but you must have created a Windows password reset disk first, before you <a href="http://www.windowsloginrecovery.com">lost Windows password</a>. But please note that the password reset disk will only work for the account it was created for and cannot be used to reset the password of another account.<br /><br />To create a password reset disk, you firstly need to log on Windows and enter User Accounts by clicking Start button, Control Panel, User and Family Safety, and User Accounts. Then you can click Create a password reset disk on the left pane (Just as shown on the below picture). A password reset disk wizard will come up, and then you can follow it to create a password reset disk.<br /><br />If you forgot Windows password, boot your computer to enter Windows logon screen. You'll get the reset password option when you type an incorrect password at the logon screen and press Enter. Click on the option and the password reset wizard will pop up to guide you to reset Windows password.<br /><br />Option 3: System Recovery Options<br /><br />Apart from Create a password reset disk, the System Recovery Options can also help you when you need to reset Windows password. You can either use a Windows installation disc or the recovery options provided by your computer manufacturer to access the System Recovery Options. Of course, you can also create a system repair disc by yourself.<br /><br />1. Type system repair disc into the search box in the Start menu and press Enter.<br /><br />2. Insert a CD/DVD into the optical drive and hit Create disc.<br /><br />This creates the system repair disc. To start the System Recovery Options, insert the system repair disc into the optical drive and reboot the PC via the disc. Select your Windows installation from the list when prompted. The System Recovery Options are now displayed.<br /><br />Option 4: Windows Password Reset Software<br /><br />Considering that many users never create a password reset disk or system repair disc, here we list option 4 - Windows Password Reset Software. The big advantage of this option is that you can reset the password easily in 5 minutes, without doing anything to in case of a lost password, like creating a disk. And it can help you reset Windows password whether you can log on your PC or not. There is plenty of such software on the Internet. Here we suggest Windows Login Recovery.<br /><br />1. Download and Install Windows Login Recovery in any accessible computer.<br /><br />2. Create a bootable CD/DVD or USB flash drive with the software.<br /><br />3. Set CD-ROM or USB device as the first boot device in BIOS for your PC.<br /><br />4. Boot your PC from the created CD/DVD or USB flash drive and reset Windows password.
on Dec 09, 2010 • Computers & Internet
1helpful
2answers
Acer veriton X275 recovery download
You can make a recovery disk by the following steps,
Step1: Download Smartkey Windows Password Recovery from SmartKey website.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
1helpful
5answers
Forgot my password
If you forgot windows password, you could create a windows password reset disk on an available computer which could download from Internet. With the disk you could perform windows password recovery. Only four steps:
Step 1: Download Windows Login Recovery from http://www.windowsloginrecovery.com/ and install it on the available computer
Step 2: Run the software and use it to burn a Windows password recovery disk (you could burn the file into the blank CD/DVD or USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the CD-ROM (Start computer and press F2 or Delete to enter BISO setup)
Step 4: Boot your locked computer from the created disk and remove the Windows password
It is easy and safe. Hope to help you.
tip
How to Recover Windows XP Password with Password Reset Disk?
Windows XP not only allows you to set a strong password to protect your computer, but also enables you to create a password reset disk to recover Windows XP password. So if you forgot Windows XP password, it is no need for you to reinstall computer. However, Windows XP has been released for several years and used by majority PC users, but there are still some PC users do not know how to create a password reset disk. Here I will show you how to create and use Windows XP password reset disk to help you to perform Windows XP password recovery.
To create a Windows XP password reset disk, you need to prepare a USB flash drive in advance before you follow the steps to create a password reset disk on Windows XP.
Step 1: Click Start button to select Control Panel.
Step 2: Click User Account on the following Windows screen.
Step 3: Select the User Account you want to create password reset disk for.
Step 4: Click Prevent a forgotten password.
Step 5: The Windows Password reset wizard will come up, Click Next.
Step 6: Insert your USB drive in computer. The next box will say Create a Password Reset Disk and ask you to insert your blank formatted disk in your floppy drive. Click the Next button.
Step 7: Enter your password at the Current User Account Password Box and click Next.
Step 8: Windows XP will create the password reset disk. When the progress indicator shows 100% complete, click Next.
Step 9: Click Finish when the forgotten password wizard box prompts you to do so.
When the Windows XP password reset disk is created, a file named userkey.psw will appear on your USB flash drive. You only need to create a disk for your Windows XP login password once. No matter how many times you change your password, this disk will always allow you to create a new one. Please remember to keep it in a safe location. And when you forget your password, you can use this USB flash drive to recover Windows XP password. Below are the Windows XP password recovery steps.
Step 1: Start your computer to enter the Windows XP log on screen.
Step 2: Type an incorrect password in the Password box, and then press Enter.
Step 3: In the following Logon Failed dialog box, click use your password reset disk. The Password Reset Wizard starts.
Step 4: On the Welcome to the Password Reset Wizard page, click Next.
Step 5: Insert the password reset disk, and then click Next.
Step 6: On the Reset the User Account Password page, type a new password twice.
Step 7: In the Type a new password hint box, type a hint, click Next, then click Finish.
Now your Windows XP password has been reset. You can log on your computer with the new password. And if forget to create a password reset disk, you can still perform Windows XP password recovery with Windows password recovery software like Windows Login Recovery. It can help you recover Windows XP password by burning a bootable CD / DVD or USB flash drive. In addition to perform Windows XP Password recovery, it can also help you recover Windows administrator password, standard user password on Windows 7 / Vista / Server 2008 / 2003, etc.
on Sep 26, 2010 • Computers & Internet
tip
Password Recovery Disk
Take preventive measures against losing user-level passwords.
It doesn't matter if you never again remember a Windows user password. Thanks to XP's Forgotten Password Wizard, your conscience will be free and clear -- should your mind happen to accidentally misplace your user password.
I highly suggest you create a password recovery disk the minute you create your user account. Why? In order to create a password recovery disk you're going to need your password. Write it down the minute you create your user account and then proceed to creating your very own password recovery disk.
Here's how to launch the Forgotten Password Wizard:
Single-click Start menu, Control Panel, and User Accounts.
Click your user account name.
Under Related Tasks on the left, click "Prevent forgotten password" to launch the wizard.
Now that you've launched the wizard, let it walk you through creating the recovery disk. Make sure the disk you use is formatted and in the drive. After it's finished creating the disk, label it and stash it away for an emergency.
If you happen to forget your password, all you need to do is click your user icon at the logon screen. Even though you don't have your password, go ahead and click the green arrow just like you would to finish logging on to your computer. This will launch a little yellow dialog box directing you to use your password recovery disk.
Bhautesh.
on Feb 24, 2010 • Computers & Internet
2answers
I forgot my password
If you could use another computer which could download from Internet, you can create a windows password recovery disk. Third party windows password recovery software windows login recovery could create such a disk. Only four steps:
Step 1: Download Windows Login Recovery and install it on the available computer
tip
Password Recovery Windows XP
Here's how to launch the Forgotten Password Wizard: Single-click Start menu, Control Panel, and User Accounts.
on Dec 17, 2009 • Computers & Internet
tip
Windows XP Tip: Password Recovery Disk
Here's how to launch the Forgotten Password Wizard to create your very own password recovery disk.
  1. Click Start menu, Control Panel, and User Accounts.
  2. Click your user account name.
  3. Under Related Tasks on the left, click "Prevent forgotten password" to launch the wizard.
Don't lose the disk, however, or you're out of luck.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
