SOURCE: wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
SOURCE: The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
SOURCE: My BlackBerry Curve will not turn on. I tried
Hi!... I suggest you have to see a technician with these problem. Most modern phones especially with problems like these needs software reformatting.
SOURCE: blackberry plugged in to charge with a red light. wont turn on!
well take it back demand a refund my friends dad has the same thing he says that it SUCKS ON ICE
SOURCE: When i plug my blackberry
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
