SOURCE: I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
SOURCE: What is the cost of a high voltage
You need to look at part number on the board assembly first, not all 19LA20Q use the same manufacturer of the inverter, once you have have the P/N, then you can go on EBAY or www.lcdparts.net. I would estimate from $30~50.
SOURCE: no signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
SOURCE: how do I hook up a DVD player to a proscan 32 inch
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
SOURCE: I have a Proscan 32
You will have to order it from Proscan. The part# and web address should be in your owners manual.
