Your unit has an access panel, at the bottom of this panel are 2-4 screws. Remove them and the panel also, unplug the unit, with your right hand and to the right of the door, use you hand to go inside the unit toward the door latch. At the bottom of the door latch is a pull down looks like a tear drop but can only be felt. This is the door release, when you pull on this gently you should hear a click. This is the emergency door release for this unit. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
SOURCE: washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
SOURCE: Whirlpool Gold Dryer
You will need a volt Volt-Ohm (VOM) reader to fix this problem.
This doesn't rquire sound technical knowledge for this but you should be good at following some instructions.
This could be the effect of a number of problems. Here's a list of things to check and details on how to do it.
SOURCE: Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
SOURCE: Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
