just run the "line audio" not your speaker audio out from your tv to the aux or dv/cd input...
on your dav-fc7 it will sound great! just turn the tv audio sound down at the set.
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV. Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
I had the same problem....but it kept taking longer and longer for it to quiet down, then eventually it just kept whining and I couldn't take it anymore...I had to stop using it for tv and only used it for DVDs (it didn't whine on the dvd function). I was going to get rid of the unit because my old tv died and I had to buy a new flat screen high-def unit, which needs a surround system to do it justice. I then noticed the digital optical connection on the Sony DAV-FC7 as well as my new Direct TV HD-DVR. I bought the optical cable for about $15 and hooked it up....and voila...NO MORE WHINE! If you have the optical connection option....try that route...it might work for you as it did for me. Good luck
If you can, use the digital optical connection....I had the same problem and switched to the digital optical connection and that worked for me....no more whine.
Now the solution (rather, a workaround) for this problem is power off the main supply (or remove the plug from the electrical outlet) and then plug it again. From now, on do not power off the unit. If you have to, then you need to perform the work around again.
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
