I appreciate your inquiry, Bill Payer!
I understand that your Electrolux range is displaying error codes "E21" and "E39" and you are waiting for a part to become available to change. Based off the error codes "E21" stands for key sensor for cook place two which means a potential issue with the left board. "E39" stands for incorrect configuration. To configure your cooktop you would need to press and hold the "Warm" key, then press right front "Power" key until it beeps. Then press left front key and the configuration should start. If that does not help your situation I would suggest having a professional out for proper diagnosis. This will help to avoid any unnecessary part purchases. Best of luck! -Matt
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
