That part would have to come from Tascam itself. If you would like to inquire about a repair, please contact me through my website at audioserviceclinic.com. Thank you.
Hi , this sounds like the fuse has blown for the central locking due to a hi amp draw from a fault lock , depending on the country that you are in you will need to find the fuse for the central locking , for european cars the fuse will be #57 or #72 it will be a 15amp fuse that will nead to be changed to a yellow 20 amp fuse , once the blown fuse is replaced , insert the romote key in its slot and turn the ignition on , then remove the key , open and close the drivers door and the central locking should then work , if this fault re-occures then 1 or more door lock will nead to be replaced, hope this is of some help , regards mark.
on the back of the control panal you nead to remove the two screws one on each side,next you nead to pull the panal forward and flip it up.unplug the door switch,next remove the two s-clips that hold the body on.pull the body forward and remove the body.next look down and you will see the water pump.if there is water under the pump than you have a bad seal in the water pump.you nead to replace the pump.you may nead a pan to catch the water that is still in the washer when you remove the hoses from the water pump.remove the two clips from the water pump and replace the pump.
you nead to replace the dogs in the top portion of the agitator.first remove the fabric soffiner despencer from the top of the agitator,next there may be a plactice cover that you nead to remove,next you nead to remove the 7/16 bolt and pull up on the bottom of the agitator and remove the agitator and place it on the floor,put a foot on both sides of the bottom of the agitator,next you nead to grab the top of the agitator and pull up and remove the top of the agitator.place your hand inside the top of the agitator and turn it upside down and remove the dog assembly.replace the rubber dogs and reassemble the agitator and reinstall the agitator.
sounds like a bad door switch,to replace the door switch you will nead to remove the body.first you nead to remove the two screws behind the control panal one on each side.next pull the panal forward and flip it up.next you nead to unhook the door switch.next you nead to remove the two s-clips one on each side.next you nead to pull the body forward and remove the body.now you con remove the two screws that holds the door switch on under the door next remove the door switch connecter from the body and install the new one.next reasemble unit
put your ear up next to the timer,if you hear it ticking than you have a bad thermal switch.you will nead to unplug the dryer,next you will nead to take off the back panal and power cord cover plate.on the lower right hand side you will see a white plastic switch with two blue wires going to it.remove the two wires,at this time if you have a continuaty meter you can check to see if switch is open,if it is you nead to replace it.
first make sure you have 220 going to the dryer.next put the timer on time cycle.next put your ear up to the timer and see if you hear the timer moter runing.if you do than you have a bad thermal switch.you will nead to remove the back panal and the power cord cover.on the lower left you will see a white plastic switch with two blue wires going to it.this is the thwermal switch,if you use a meter and this switch is open than you nead to replace it
I AM CURENTLY AWITING ANOTHER REBOOT DISK AS THE MANUFACTUERS OF THE LAP TOP SAID IT MIGHT NEAD THE FULL INSTAL OF VISTA HOME BASIC AND NOT JUST THE REBBOT PROGRAM VERSION I GOT WITH THE PC. AS THIS DOES NOT INCLUDE THE START UP SETINGS THAT CONFIGS THE BIOS TO USE VISTA. ( I DIDNT UNDERSTAND THIS TILL I ACTURLY GOT INTO THE BIOS) THE NEW DISK WILL ASLO INCLUDE A NEW PRODUCT KEY THAT DOES NOT NEAD TO BE CONFIRMD VIA INTERNET TO USE AS IT IS JUST THE BASIC VISTA PROGRAM THAT SHOLD ALOW ME TO INSTAL MY UTILITIS AND DRIVERS TO INSTAL THE MODEMS AND OTHER SYSTEM FILES. WHEN I ORIGANLY GOT THE LAP TOP IN 2007 THE REBOOT &RECOVERY DISKS ONLY HAD THE SET UP PROGRAMS THIS ALOWS YOU TO INSTAL VISTA OPERATING SYSTEM BUT NOT ALL THE PROGRAMS WILL WORK AS YOU NEAD TO DOWNLOAD THE FULL SYSTEM SETINGS. SO JUST TO LET OTHERS KNOW IF YOU GOT A LAP TOP OR PC THAT ONLY HAD A REBOOT DISK TO CHEK THAT IT IS THE FULL VERSION ( NEW VISTA RECOVERY 2008 ) AND NOT THE 2007 ONE
