Question about Microsoft Word 2010
How can chapter titles be inserted into an existing document in Microsoft Word 2010?
I have written a manuscript in Microsoft Word 2010, and I need to insert chapter titles in it. How do I do that?
Insert The Chapter Number And Title In A Header Or Footer
First divided your document into sections in order to insert chapter numbers and titles into headers and footers.
1. If you haven't done so already, insert a section break where you want to start a new section that contains a different chapter.
a. Click where you want to insert a section break.
b. On the Insert menu, click Break.
c. Under Section break types, click the option that describes where you want the new section to begin.
Note: If you have already inserted a page break to cause the chapter to start on a new page, delete the page break and replace it with a section break that starts on a new page.
2. Apply a built-in heading style to the chapter number and chapter title by clicking a heading style in the Style box on the Formatting toolbar.
Or to have Microsoft Word automatically number headings, use the Bullets and Numbering dialog box to format chapter headings.
a. On the Format menu, click Bullets and Numbering, and then click the Outline Numbered tab.
b. Click a chapter-numbering style (one that includes the text "Heading 1" or "Heading 2," and so on), and then click OK.
c. Type the text you want for the numbered heading, and then press ENTER.
d. To add the next numbered heading, go to the next chapter heading, click the arrow next to the Style box on the Formatting toolbar, and then select the heading style you specified in step 2.
1. In the first chapter, on the View menu, click Header and Footer.
2. If necessary, move the insertion point to the header or footer you want to change.
3. Insert the chapter number or title.
a. On the Insert menu, point to Reference, and then click Cross-reference.
b. In the Reference type box, click Heading.
c. In the For which heading box, click the heading that contains the chapter number and title.
d. In the Insert reference to box, select what you want to insert in the header or footer. For example,
• Click Heading number to insert the chapter number.
• Click Heading text to insert the chapter heading.
e. Click Insert, and then click Close.
4. Click Show Next Button image to move to the header or footer of the next chapter.
5. If the header or footer in this chapter matches the one you just created, click Link to Previous Button image on the Header and Footer toolbar to break the connection between the header or footer in the current chapter and the previous chapter.
6. If there's already text in the header or footer that you don't want, delete the text before inserting the chapter number and title.
7. Repeat step 5 to insert the chapter number or title of the current chapter.
8. For each chapter in the document, repeat steps 5 through 9.
Posted on Aug 10, 2014
2 Suggested Answers
SOURCE:
fblock
  • 289 Answers
SOURCE: Revision Date Insert into MS Word
Since you would be "saving" a change to the document (being a revision), you may want to look into inserting a "Field" named "SaveDate" so it will hold the date the doc was saved.
Position your cursor where you'd like the date to be in your docuemnt, then: Insert > Field... > In Field names, select SaveDate, select a format and click <OK>.
Hope this helps!
Posted on Apr 21, 2009
Issue Opening docx file
·Close Microsoft Word, then click Start, Run, type winword /a and press Enter. Try to open the document using this copy of Word.
·Try to insert the damaged document into a new document. Create a new document, then click on Insert, File, select the damaged document and click Insert.
·Try opening the file using WordPad then re-saving it to a new file, or copyimg the contents and pasting them into a new Word document.
Or try using a Microsoft Word document recovery tool such as Word Fix Toolbox
https://www.fixtoolbox.com/wordfix.html
Aug 31, 2015 | Microsoft Word for PC
Tip
How To Password Protect & Decrypt Microsoft Office 2010 Documents
Microsoft office 2010 , the next big buzz from Microsoft after Windows 7, is a productivity suite for Microsoft Windows,and the successor to Microsoft Office 2007.
Screenshots of Microsoft Office 2010
Not long ago I was just wrote an article about How to Password Protect Microsoft Office 2007 Documents. Now I’ll write a similar article about office 2010 by popular demand.
Microsoft Office 2010 indeed simplified the process to password protect and encrypt office documents. Which was considered a commendable improvement over password protecting documents under Office 2007. as the new process for Office 2010 is consistent across the core Office product line which including Word 2010, Excel 2010, PowerPoint 2010 etc. so here I only need to show you how the process just once using Microsoft Word 2010 as example.
Follow the step-to-step guide To Protect A Word 2010 Document Using Built-in Password Encryption
1. Click the File tab, then Click Info. On the menu to the right Click Protect Document and
Click Encrypt with Password.
2. The Encrypt Document dialog will appear, Type in a password and then Click OK to finish.
Please note – It’s very important to use a STRONG Password or Pass Phrase to protect your word document. Using a long PASS PHRASE (IE:I enjoyed myself today!) however with 10 or more characters will significantly increase the encryption strength of the document and decrease the likelihood someone will be able to break the encryption and gain access to your document.
After setting a password, your document should be protected!
Having password protected your word document? Someone should ask what if I forgot the password. So that’s what I’ll show below.
Follow the step-to-step guide To decrypt Word 2010 Document Using word password recovery 5.0
With this user guide, even a new user can fully control Word Password Recovery 5.0 in less than a minute.
Step1: Click “File>Open” in the Menu or the “Open” button to browse in the Word document.
Select your file in the Open File window, and click “Open“.
Step2: Select “Brute-force Attack (Trying All Possible Combinations)“.
Step3: Click “Start” button in the Menu to initiate the program.
Step4: The program is searching the password. Some time later, a message box pops up to you, displaying the expected password. Click “Remove All Passwords from the File” to remove all passwords (Password to Open and Password to Edit) from the file. Click “OK“.
Following this article, you could password protected your office 2010 and decrypt password protected office 2010 with ease.
on Jun 30, 2010 | Computers & Internet
Tip
DVJ-X1 Cue before inserting disk.
The DVJ-X1 has a fun little bug/feature that is often over looked.
For a cd press the track forward/previous to select the track you want to play BEFORE you insert a disk, once you have the disk inserted and it initializes the deck will cue to that track automatically.
With a DVD you need to also select the TITLE as well as the TRACK most of the time with promo only or rock america disks there is only one track for videos so select TITLE 01 first then the appropriate Chapter.
on Jul 16, 2008 | Pioneer DVJX1 Turntable
I have created a 1-page document (colored green with print) to use as a book cover. I can save the document but cannot copy/paste it to the first page of a different document (my manuscript). How is
Y ou mentioned that y ou have created a green page but not how you made it ....
Have y ou tried ti simply create an image and insert TNA image on tour first page ? Y ou clan adjust The seize of The image to fit The entire page
Aug 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I want the DVD to repeat but the logo is there
Have you checked their website? Awesome place to start.
May 20, 2014 | Curtis International Proscan 32" Class LED...
How to remove headers on chapter pages only with word 2010
That would depend on how you have your document set up.
If each chapter is defined as a "section" in Word, when editing the header for each section, in the Design tab, Options panel, select Different First Page.
That will make the header appear only on the frst page of each chapter.
If this isn't what you meant, please be more specific about the layout of your book, document, chapters, etc.
Mar 21, 2014 | Microsoft Office Professional 2007 Full...
Hi there when i log into slide show expressions i get a ' black/blank window right in the middle of the title page. pse HELP i need to remove this window
This is quite normal. It just means that no project is opened up yet. You need to either create a new project / slide show or open an existing one. The little black window in the middle is only "reserving" the spot where the chapter icon will appear on your menu page once you've newly created a chapter or slide show. Later on, the little black window will be replaced with one showing one of the photos you have inserted - you can choose which photo you want to display as chapter icon. You can also alter the position of these chapter icons in the "Design" tab.
Aug 17, 2010 | Individual SlideShow Expressions
This may sound trivial, but my husband has written a WordPerfect document and needs to add a title page at the very beginning. We can't figure out how to insert the page without messing up the whole...
Well, I don't know wordperfect very well, but if the document is going to be delivered in printed form, you could always just create a new, one-page document as your title page and print the two documents separately.
Nov 13, 2009 | Corel WordPerfect Office 12 Home Edition...
Microsoft Word 2010 Logo
252 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
