Yamaha G1 G-1 2-cycle Gas Golf Cart Tune Up Kit 78-89 Logo
j
joe c Posted on Aug 04, 2014
Why does it start good then only ***** around slow -yamaha golf cart
I have a 1991 G2a golf cart. It starts and runs good for the first few moments, then it bogs out and only puts around! Any solutions to my problem thanks. joe
miraj_music
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on Aug 10, 2014
miraj_music
Contributor
Level 1:
New Friend:
Answers
42
Questions
0
Helped
12208
Points
71
Check the air bleed screw in the gas cap that it is undone
My golf cart has to crank more than necessary before engine starts. Choke does not seem to make a difference.
The carb choke circuit is most likely plugged which is why it has slow starting. The clunk may be from the engine idle being set to high. It probably is running high idle because it has carb issues and the fuel system may need cleaning.
1helpful
I have a g1 2stoke Yamaha cart it cranks for ever before it starts.wants it starts it takes off then falls on face.finally it will start to run.but every time it set's for awhile. I go through same.
Yamaha Golf Cart Service Repair Manual & Parts G1 G2 G9 ...
www.amazon.com/Yamaha-Service-Repair-Manual-Pa...
Amazon.com, Inc.YAMAHA ILLUSTRATED PARTS & SERVICE MANUALS This is a Yamaha Golf CartIllustrated parts and Service Manual. The Parts manual includes every part ..
2answers
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Yamaha golf cart
Look under the seat for a pressure switch.
5helpful
3answers
1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
