When I turn this unit on it comes up with the Lowrance Elite logo nothing else happens this is the third replacement unit from Navico they have all had the same problem
It's either a software or processor malfunction. Make Lowrance fix it or make it right by you. 3 in a row all with the same issue means they have a major issue they need to resolve.
Don't take no for an answer. I've seen recurrent problems through the last couple of generations of mid priced 4" & 5" systems.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
SOURCE: I NEED REPLACEMENT ROLLERS ON MY LOWRANCE X16
We have a x-16 that hasn't got 10 hour total on it. It was used on Sheriff Dept rescue boat and has been storage since late 80's. 25.00 and you pay shipping buys the unit and a case of paper for it. It doesn't have the power cord or transducer with it. That was misplaced years ago.
SOURCE: Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
