Sony HVR-A1E HDV Digital Camcorder Logo
A
Anonymous Posted on Aug 04, 2014
The menu icon wont function
The open menu on page one of four when touched activates shutter speed. Each icon on the four pages at the top of the LCD screen when touched activates the icon at the end of the screen?
Sheryl Bahr
Level 2:
Producer:
Uploaded 30 video answers.
Filmmaker:
Uploaded 5 video answers.
  • Sony Expert 65 Answers
  • Posted on Aug 04, 2014
Sheryl Bahr
Sony Expert
Level 2:
Producer:
Filmmaker:
Answers
65
Questions
0
Helped
25860
Points
190
This video goes over the problem you are having.
1 Related Answer
Anonymous
  • 619 Answers
  • Posted on Jan 10, 2008
SOURCE: None of the icons On LCD screen is working
If you have computer re scan w/ anti virus the camera , try to fix into computer / you may ask web site of sony you may down load the driver of the camera.
How do I get google as my home page
  1. Open Google Chrome.
  2. In the top right corner of the page, click the Chrome menu alt="Chrome menu">.
  3. Click Settings.
  4. In the "Search" section, select Google from the drop-down menu.
Mobile
  2. In the top right corner of the page, touch the Chrome menu alt="Chrome menu">.
  3. Touch Settings.
  4. In the "Basics" section, touch Search engine.
  5. Select Google.
Feb 16, 2015 • google.com
How do I change my email address
You can change the personal information used with your Kobo account in your Account and Profile settings.
These details allow us to complete your purchases in the Kobo Store, or let you opt in or out of Kobo email updates and offers.
  1. Go to kobo.com
  2. Sign in to your account with one of these options, depending on what you see:
    • Click the >Profile icon at the top right of the page, then click Sign In.
    • Click the >Menu icon at the top left of the page, click the >Profile icon, then click Sign In.
  3. Enter your username and password.
  4. Click Continue.
  5. Open your account details with one of these options, depending on what you see:
    • Click the >Profile icon the top right of the page, then click My Account.
    • Click the >Menu icon at the top left of the page, click the >Profile icon, then click My Account.
  6. Make your changes.
  7. Click Save. Your account will be updated to reflect your changes.
1helpful
LCD Screen won't turn on. I can take pictures just fine but the screen just won't turn on. Hasn't been dropped or exposed to water at all. Canon EOS Rebel T3i
There are a few thing you may want to look at. In your menu settings (the second little wrench icon) you will find the LCD on/off options: Shutter Btn, Shutter/Disp, and Remain on, select your desired setting (page 179 in the T3i manual) Check to see that the display is activated by the "DISP." button located just in front of the Mode Dial. For the display to remain on during shooting you must me in "live view" which is avctivated by the icon button located to the immediate right of the eye cup. Unless this "live View" option is selected the LCD will remain off to save power. Also, if the menu is not visible try activating the quick menu "Q" button located just below the apature "AV" button. The LCD should work in the play/review mode at all times, if that is not the case then maybe repairs are necessary.
You can view the manual from the link:
http://www.bhphotovideo.com/lit_files/16003.pdf
My kindle fire pg is sideways and will not turn upright..what do Indo?
You have asked about the Kindle eReader, but your question refers to a Kindle FIRE.
On the eReader touch the Aa button and select the correct orientation that you require.
On the FIRE drag down from the top to reveal the top MENU - select the CIRCLE icon on the left which is the SCREEN LOCK icon. Turn it off.
The printer sounds like it is printing but the page comes out blank.
Problem Blank Pages; Blank Print Out Solution
Symptom
When printing from the S or Pro Series printers, you may encounter blank pages being printed.
Solution
To rectify this issue, please follow the troubleshooting steps below:
Action Image 1
While on the main screen of the printer, open the cover.
  • If the printhead stays to the left, go to Step 2.
  • If the printhead comes to the center, do not continue troubleshooting because the printhead is faulty.
ss_mainscreen.jpg 2
Place the printer into "Replace Printhead" mode using the Maintenance menu. To access this mode, follow the steps below:
  • Touch Screen Printers:
    • Tap on the Ink Levels icon.
    • Tap on More Options.
    • Select Replace Printhead.
  • LCD Screen Printers:
    • Press the Setup button and use the arrow buttons.
    • Select Maintenance.
... 3
Open the covers and look into the printer on the left-hand side where the cartridges are inserted into the printhead - aWICKING PAD is located there.
  • If this PAD is BLACK (as seen in the right-hand image; click it for larger view), then the printer has successfully gotten ink into and through the printhead.
  • If the PAD is WHITE, then the printer has not been able to make the ink flow through the printhead. Go to Step4.
pad.jpg 4 Seat the printhead again. Unpower the printer and connect it again. Open the cover and reseat all four tanks. Press firmly on the rear of each tank and make sure all four snap in tight. ... 5
Insert plain paper and run Deep Clean.
    • Select Deep Clean Printhead.
    • Press the Setup button.
If you cannot get all four inks to lay clean, identify which one, if any of them, is failing.
  • If there is just some ink on the page - run the Deep Clean again.
  • If there is no ink at all, then the printhead is faulty.
1helpful
2answers
How do make the flash work?
Good day, click the link below and download manual. hope it will help to your problem.
users manual
thank you.
IS THIS CAMERA WATERPROOF AND HO DO U TURN ON THE FLASLIGHT
No, the camera is not waterproof.
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
1helpful
How do you use the flash on a vivicam 8025?
2helpful
How do I turn on the flash on 8025
1. Touch the flash function area (lightning bolt with downward-pointing arrow) until the flash icon with the "A" shows up on the left side of the display. This activates the automatic flash.
2. Touch the flash function area again until the flash icon shows up. This activates manual flash.
3. Touch the flash function area again the eyeball icon shows up on the left. This activates the red-eye reduction mode feature.
4. To turn off the flash, touch the flash function area repeatedly until the flash icon insie a circle shows up.
This is all explained on pages 13-14 of your manual.
1helpful
My vivtar 8025 camera locked my pictures so I can't delete the, how do I unprotect them
1. Press the Home button.
2. Enter Playback mode by touching the Playback (right-facing triangle) function area.
3. Press the Menu/OK button.
4. Touch the downward arrow function area until the Protect option comes up.
5. Touch the key icon function area to enter the Protect menu.
6. Touch the left arrow function area to select Lock or Unlock.
7. Press the Menu/OK button to confirm.
This should be on pages 29-30 of your manual.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
