I am unable to find driver for the Consumer Cellular flip phone Envoy/Huawei U3900
I figured this out. You need to add a memory card (SD micro) to the phone. Then internally move the photo files from the camera's internal memory to the SD card (done through the gallery menus). Once you have them moved to the SD card, plug the phone into your PC and it will recognize the SD card in the phone as an external drive. From there its easy. :)
SOURCE: my blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
SOURCE: Unable to setup communication between cellular phone and laptop.
i had the same problem. when i installed the usb driver i got that message too. but after this i installed pc studio 3 and with the phone explorer it worked for me.
SOURCE: need a subsidy code for
To get the subsidy code For that Phone you can reach here
Theunlockspot.com
Unlock NCK code huaweiU3900
