if this happen out of the blue and your pc was running fine before what it means is that your boot loader fill is corrupt or your os has been corrupted you will have to ether reinstall your os or try to repair with your os disc.
If XP where your primary OS this would not be a problem. Since Vista is the Primary you are going to need to get a boot loader that will start before either OS does and use that to choose OS at bootup.
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
Try booting into safe mode. That will disable all drivers and use generic windows drivers to send commands to the devices. If that still doesnt work, id say that there is a problem with your OS installation. Backup your files using an external harddrive enclosure and reinstall the OS.
best practice it when installing windows and linux install windows first and then linux. GRUB or LILO boot loader is much better then windows boot loader and very easy to reinstall. Mandriva cd should have a rescure feature that will allow you to reinstall the boot loader.
I beleive that you are installed windows first and linux second,then dual booting will be configured automatically ,means linux will install the grub (boot loader)and configure it with what all Os u have.If your system is not booting and showing grub menu do one thing ,boot it from a linux cd and reinstall grub.
