HP W2371D 23 Full LED Monitor 16:9 5ms 1920x1080 250 Nit 1000:1 DVI/VGA Black - - Retail - B3A19AAABA Logo
A
Anonymous Posted on Aug 04, 2014
Mouse cursor disappear on hp w2371d - HP W2371D 23 Full LED Monitor 16:9 5ms 1920x1080 250 Nit 1000:1 DVI/VGA Black - - Retail - B3A19AAABA
Bob Sloan
Level 3:
  • HP Master 2,013 Answers
  • Posted on Aug 08, 2014
Bob Sloan
HP Master
Level 3:
Answers
2013
Questions
Helped
356968
Points
8519
See this... http://h30434.www3.hp.com/t5/Desktop-Lockups-Freezes-Hangs/Disappearing-mouse-pointer/td-p/1568463
If it only disappears when you move it left or right off the edge of the screen, your video software may think you have a second monitor. Tell it different.
1helpful
3answers
Cursor disappeared
If you have multiple screens set up it might be on one of the 'extra' desktops. Very deliberately drag your mouse in one direction 3-4 times, change direction and do it again and again until you see the mouse pop up. Also if you are good at navigating by keystroke you could go into your display settings and remove any extra monitors. Hope this helps!
Cursor disappears & reappears while texting
This is normal. You alter the setting in the Control Panel:Mouse.
3answers
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Cursor disappears lenova yoga
Press Fn key and F7 key together
1helpful
The cursor (arrow) sometimes just disappears and to get it back I have to restart the laptop. Is there a function button that would fix it??
What is running when it disappears and windows has options for the cursor in control panel > cursor /or win XP control panel > mouse
Mouse/cursor works fine on PC but disappears when watching recorded TV using windows media center. model KB3800TPW
Usually when watching something on your computer in full screen the cursor will disappear. If it comes back when you move the mouse then you have nothing to worry about.
1helpful
The cursor moves all over when I type and sometimes disappears sometimes all the text disappears and sometimes any key will close the program this is a problem with all typing I use wireless connection
You have a corrupted operating system - if you want to you can turnoff the mouse touch pad by the button just infront of the mouse pad but I've seen this before - all software related - you have major conflicts with device applications - do an F11 system recovery after backing up your data & don't forget your email adress.
1helpful
Cursor
HAI,GO TO CONTROL PANNEL ,THOOSE TO CATEGORYVIEW ,THEN SELECT MOUSE OPTION ,MOUSE PROPERTIES ARE DISPLAYED CHANGE TO YOUR DESIRED OPENION .
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
