Replaced the electronic board on washer, it now flashes a fault 9 code and will not operate, says call service technician is there anything that can be done at home without calling tech
Fault 9
LAH HIGH CURRENT FAULT
The low ambient heater is drawing more current than expected. Either the heater or wiring is faulty.
Primary Action
- Check the wring and connections at both heater and power module.
Secondary Action
- Check heater resistance. If not within limits replace heater.
SOURCE: new fisher and paykel washer WL26CW fault code 245
the drain pump impeller is seized; you just need to turn it a bit and will work just fine afterwards.
