Intuitive eco wont pump out came up with code 37 thanks
SOURCE: fisher and paykel intuitive error code 37
Dear chopper667,
ngfam1 here for you!
I am happy to be of assistance!
Try unplugging the washer and then rebooting it after 3 minutes!
If this fails,
here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
SOURCE: Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
SOURCE: Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
SOURCE: fisher and paykel intuitive washing machine not spinning
to remove the pump - remove power pins. Press bayonet clip in [lhs of pump base. Twist anti clockwise. Remove blockage. Rub a smear of Vaseline on seal before re assembly
SOURCE: we have a fisher and paykel intuitive eco, which
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
