I put batteries in , it says HELLO on the lcd screen , but will not turn on the receiver, none of the buttons seem to work.
Clean the remote with an alcoholic solvent then try to look for any loose joint mostly near the LED transmeter then use your mobile phone camera to check whether light is visible when you press the remote buttons while directing it to the camera
Testimonial: "Remote works with everything else but the Receiver."
SOURCE: pioneer remote for receiver
It's quite likely the codes are the same. Check the manuals for the models on Pioneer's website (www.pioneerelectronics.com) for the year/date they were issued. For most models issued around the same time the codes were the same, but they also post IR codes, so you can verify there as well. If you can't find any information I will give you info on ordering the exact remote you need and options for universal remotes that have your model.
Regards,
Vincent J. Bova
Total Control Remotes
Programming Remotes & Advanced Control systems
www.totalcontrolremotes.com
saw the light in remote, programmed it to turn on my Sony HDTV , but it won't work with the receiver
