Re: what do i do when i dont know how to register my...
Contact www.amazon.com Next to the search bar you'll see Your Account. click, choose Your account from the list and click. Next page, far right column you will find help desk options. follow that to leave a message for them. They can send an email with instructions or call you back and walk you through it.
There are many user guides and manuals available for download on the Kindle Documentation Page on Amazon's website. This is probably the best place to start and should have the most information about all models.
Kindle Fire 2011 1st generation, but to double check it open the settings and see if it runs 2.3 or 4.0 operating system. If 2.3 it's a first generation.
Step 1
Press the "Power" key to wake the Kindle from Sleep mode. The Password prompt displays.
Step 2
Type your best guess at the password into the Password input box. Retype password guesses a total of four times. After the fourth incorrect password entry, the Reset dialog box opens asking if you would like to reset the Kindle Fire.
Step 3
Tap "OK Reset" to reset the device to original factory settings.
Connect the Kindle Fire to a wireless network and re-register the device with your Amazon account.
Tips
Tap the "Show" option in the Password dialog box to display the password characters as you type.
Visit the Amazon.com Reset Password page to reset your Amazon.com password (see Resources).
Warning
Information provided in this article applies to the 1st generation Kindle Fire. Instructions may vary slightly or significantly for other models of the Kindle Fire.
Amazon is cautioning clients of more seasoned Kindle tablets that they In the event that the issue continues, if you don't mind restart your Kindle from the Menu in Settings and attempt once more. Arouse fifth Generation. Encourage Touch fourth Generation. Encourage Paperwhite fifth Generation. First gander at Amazon's Fire tablets For more help related kindle devices contact our kindle customer services number +1-844-769-9823.
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
I don't think its your charger. The charger port can get loose after time. This is a known issue with Kindle fire 1st generations. Kindle fire 2nd generations have issues with the battery itself. But the issue with the Kindle fire 1st generation is not the ac adapter. The micro usb port attached to the kindle breaks or becomes loose. Bad soldering is the issue.
