WHY AM I GETTING A FAINT LIGHT LINE DOWN THE RIGHT SIDE OF THE PAPER
There are many things that can cause a line. Most commonly the charge wires for the drum units will get dirty causing lines. If you open the front door and look below the toner cartridges you will see the drum units. On each drum unit there is a charge cleaner. They are small blue knobs. Pull these in and out a few times (they do not pull all the way out). That will clean the charge units. If you still have a line or lines after cleaning, there may be a more serious problem.
Other causes could be fuser, transferbelt, or damaged drum. You would need a technician to property replace these parts.
Please attach pictures ....i have to see for better understundaning and solving your problem.
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
