? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Are you sure its two red lights blinking and not the one red light blinking and you can see it through the other window to look like two red lights? If so sounds like your lamp is blown. Open the back door and unscrew the lamp (2 phillips screws) and check to see if your lamp is blown.
plug the transmitter into a usb port. make sure batteries are in the mouse and the switch is on. press the button on the transmitter and the red light will blink slowly. next, press the reset button on the bottom of the mouse. when the red light on the transmitter blinks fast, it has connected.
It's not coming on probably because the safety sees a short and is sparing you smoke damage. Double check to make sure any solder didn't cross or drop to another set of solder joints on the bottom. You might be able to get a service manual from here that could tell you more about the lights -> https://www.manualsparadise.com/ShowProductsForModel.do?model=M22931911
