2010 Ford F-250 - King Ranch - Punch Grille Logo
A
Anonymous Posted on Aug 02, 2014
I need help
I have a problems with my electric mirrors. The passenger mirror will not fold in or out it is completely dead , but the power slide still works and the mirror glass still works. The drivers side mirror when you operate the fold button sometimes the mirror tries to fold in and out or the mirror glass tries to move when you try to alter the power folding. Also the power slide works and the mirror glass adjustment still work. Please can someone help!
Jim Hoak
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Aug 04, 2014
Jim Hoak
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
28993
Points
130
It sound like to me that the controller for the mirror is going bad
you may want to go to the junk yard and take one out of a wrecked
truck with low miles or one Gathas been tested
1helpful
Any one had issues with replacing a 2007 Chevy tahoe power folding mirrors?
so did not scan the PCM to learn why it fails?
we never ever skip scans today modern cars MUST be scanned first
after fuses all good (endless posted here same words )
outside mirror electrics seen in the service manual
I am reading it now
left side front fails
the mirror runs off the DDS, model, driver door switch controls
so mirror left//right up down work but the fold motor is dead
well the DDS is bad or the wires to it are bad
or comms fail. not scanning the PCm/BCM means not seeing errors.
the DDS has 4 switches
2 for extend and retract
and 2 to drive the motor, so 4 wires there. can fail.
I say DDS is bad. or connectors rusty or wiring damage there.
HOW CAN I FIX
First thing to check is the control switch. The next thing is the wiring to the door and the last thing would be the mirror itself.
2helpful
I NEED HELP
Since some features work on both mirrors sounds like a faulty control panel.
3helpful
2answers
Where to add side mirrors on a 58 ford Fairlane
I've had the same quandary with my 59 Ford Custom 300 and the more of them I've looked at, the more I've noticed it seems to be personal preference. Mine are currently positioned just to the side of dead center on the top and directly across from the hood cowl side to side. I've seen some positioned on the fender just ahead of the doors or even on the doors to about a third of the way down the fender. I'm getting ready to move mine rearward, I like the look. It's all your vision, my friend. Good luck!
How to replace passenger door side mirror 2012 ford flex
The related help links are mentioned below.Click the link below:---
---------How to remove rear view mirror metal foot?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-rear-view-mirror-metal.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
----How to Remove Outside Mirrors on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-outside-mirrors-on-acura.html
-------Passenger side Folding Mirror is not operating? http://schematicsdiagram.blogspot.com/2011/12/passenger-side-folding-mirror-is-not.html
These will help.
Thanks.
2helpful
2007 passenger folding mirror will not work
{: ) Have someone control the power fold buttons, while you check closely the passenger mirror. If you can feel or hear even a faint hum of the motor while commanded, try giving it a little help, but don't force it if you think it doesn't have enough power to extend or retract itself. The motor could be really stuck or inoperative.
Sometimes when the mirror has been accidentally or manually folded, it needs to be reset by just pressing on the fold buttons a few rounds and let the mirrors fold by itself. Like an exercise.
If you hear the humming noise whenever the fold buttons are pressed, we can assume that the circuit on that side is ok since it is responding electrically, and that a jammed or stuck mechanism is preventing it to move.
If you don't feel or hear any humming, as in totally no sign of response, then there will be additional considerations before deciding to go for a replacement mirror. You will need to confirm if the fault is on the wirings, a door module, or the mirror motor itself. A scan tool test may be recommended for effective diagnosis.
The power fold mirror can be serviced as an assembly. So, goodluck.
2008 Chev Suburban 4wd Z71 1/2 ton; several items on my passenger side stopped working: my passenger side front seat heater stopped working; the passenger side electric mirror stopped working; the signal...
Power windows an locks work ok ? Do you know anything about automotive electeronic control modules ?
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a 4 position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a 3 position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Memory Switch, if equipped with memory mirrors--Supplied power by the DDS and provides a voltage signal to the DDS upon a switch activation
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Powertrain Control Module (PCM), if equipped with memory mirrors--An electronic control module that requires programming when replaced and provides the message indicating transmission gear selection
• Driver Information Center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a an electronic control module that requires programming when replaced and is used to personalize the memory recall functions
• Fold Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1023
Circuit/System Description
The driver door switch (DDS) and front passenger door switch (PDS) each contain switches that control power door lock and window functions. The DDS also contains the control switch for the power outside rear view mirrors. These switches are integrated within the door control modules and are not serviceable as separate components. The DDS and PDS monitor these switch inputs for internal faults and set B1023 00 if any are detected.
You could have any number of problems an without testing , hooking up a scanner that can check DTC'S in the door module ,electrical circuit testing etc... we'd only be guessing . Your best bet mite be to take it to a qualified repair shop.
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
4helpful
Installing a Nissan Sentra Passenger Side Manual Non Folding Mirror.
had to install a driver side non folding mirror, fairly simply to say the least. There's a cover on the interior of the door, near the window, remove the cover, remove the 3 screws, need i believe a 10mm socket. If a power window, unhook the circuit. Replace new mirror.
Top Putco Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Putco Vehicle Part and Accessory Expert? Answer questions, earn points and help others
