I pressed reset on my Sony Ericsson K800i and all it says is please wait
I charge my se k880i, the reslut is the battery gets hot, but not full charge and when i open the phone it will no open, is it true that se phones have no available spareparts and is expensive?
Plz plz plz hellp me my mobile SE k800i is not working i pressed master reset and it turned of and turned back on and it said plz wait ive tried evreything plz help thanks you
Just Click On The Problem or
Phone Model For Solution,
Motorola RAZR V3
Unlock Software Hardware
Motorola SLVR L7
Motorola RAZR V3i
Sony Ericsson K800i
Sony Ericsson W200i
Hope These Works
It's me again, the guy who posted the solution found on the american site.
My problem finally solved. I tried many things, but finally I did it. I was charging the phone with the SIM and the memory card removed. I tried to make the phone start but it said again "please wait" and then I pushed for a few seconds the joystick of the phone. And the phone started. I inserted the SIM and the phone was functioning again.
So, good luck!
I found this solution on an american site. It didn't work for my phone but maybe you'll be luckyer. So, good luck!
Remove the battery while the phone is powered on and on the please wait screen. Leave it for 30 seconds. Plug the battery back in and remove the SIM and memory card. Connect the charger. Leave it for an hour. Power the phone on with no SIM or memory card.
Instructions
Obtain the unlock code for your K800i if the phone is locked. You can
get the code from an unlocking service, or from the carrier that originally
sold the phone.
Turn off the K800i and turn the phone over.
Remove the battery cover by sliding it toward the bottom of the phone.
Lift the battery from the bottom and set the battery cover and battery aside.
Remove the old SIM card by sliding it out from under the metal clip. If
you have an unlocked K800i, all you need to do is insert the SIM card from your
new carrier. Otherwise, leave the SIM out and reinstall the battery and battery
cover.
Turn the phone on and wait for it to boot up.
Press left on the navigation pad and press "*" twice, then
press the left arrow again. The phone will display "Personalize with
MNC2."
Type the unlock code and wait for the phone to reboot.
Turn the phone off and insert the new SIM card.
i updated my software through downloadng it, then changed the battery after finishing all the steps, now it won't turn on:(
what did you do
Sony Ericsson K800i Cellular Phone same problem i reseted the phone and after it didnt switched on wat i must do plz
k800i shows please wait after i do master reset...
C902 shows please wait after i do all reset
hi i have the same problem i hit the reset all and when it restarted all it says is please wait. any solutions?
how can i access my cellphone.they are no signal?
