SOURCE: My lexmark S405 willnot receive faxes. It is
Assuming "cable modem" as some kind of DSL modem using your phone line for internet. Both your modem and MFU should be connected to the wall by a filter-separator, usually supplied with your DSL modem. Check its presens and proper connection. Remove any other joints or splitters
SOURCE: I have a Lexmark Interpret
It sounds like the printer is having problem recognizing the printhead. If you're getting "Printhead Error", make sure you have the latest firmware update. You can download and install it from Lexmark at http://bit.ly/adzmDq. If you continue to have trouble, contact Lexmark technical support. Thanks.
SOURCE: my lexmark interpret s405 is
There is a recent firmware update that fixes the problem you are describing. Click on this link: Lexmark Interpret S405 Firmware Update to download the update. If you encounter any problem updating your printer, please contact Lexmark technical support for additional assistance. Thanks.
SOURCE: I have obtained a Lexmark
The link below take you to the Lexmark Interpret S405 page to download drivers and software. You may have to change your operating system (OS), the default is Windows XP 32-bit. You want to click the "More>>" button to find the link called "Complete drivers and software for setting up,....". You probably dont need to update the firmware unless there is a problem after installing.
Lexmark Interpret S405 Software and Drivers
I hope this helps you. Have a great day!
SOURCE: lexmark S405 not reconising magenta cartridge
Make sure that your printer firmware code is updated. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first
download in the list. If it is the wrong firmware level, an error message will
tell you which firmware level is correct. The firmware update addresses the problem you mention - printer having trouble recognizing the cartridges and it will help improve your printer's overall performance.
Should the problem continue even after updating your printer, it would be best to contact Lexmark technical support center for additional assistance.
Please visit the Lexmark website to download and install the Lexmark Interpret S405 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
