Prints blank pages
SOURCE: hp 1300 printing blank margine lines
hello it was your printer fuser asembly problem and in fuser u have teflion flim which was demange so u need to replace teflion flim
SOURCE: My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
SOURCE: I have an HP C7280 AIO printer. Everytime I print,
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
SOURCE: HP 4500 Printer blank pages
Every so often? Sometimes if the printer is set to print on Legal sized paper (8.5" x 14") it will take an extra blank sheet if the sheet sizes are letter. This may cause every other page to be picked up and drawn through the printer as a non printed page.
SOURCE: hp lj cp1518 printer printing blank pages
you need new ink if not used it will dry up. if you are not sure go buy black ink
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
