LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
R
Robert Dunbar Posted on Aug 02, 2014
Why is my LG french door act like is has no power?
No lights when doors or freezer open not cooing.has power at outlet
Michael
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 02, 2014
Michael
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
22120
Points
Probably a bad fuse on the main board. Fuse is not replaceable so either you have do a workaround (search LG refrigerator fuse repair for several fix videos and how-to's) or you have to replace the whole control board (part EBR41531302 I believe, but double check with your the part vendor before ordering).
Check the fuse by pulling the refrigerator out, unplugging, taking off back control board panel, and checking the fuse for continuity.
  • Michael Aug 02, 2014
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jun 17, 2008
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Anonymous
  • 828 Answers
  • Posted on Jul 31, 2008
SOURCE: LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Anonymous
  • Posted on Apr 30, 2009
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Anonymous
  • 1136 Answers
  • Posted on Jun 05, 2009
SOURCE: the bottom of my lg french door bottom freezer
Hi, The defrost drain is plugged. UNPLUG the refrigerator. Remove the rear inside panel in the freezer section and locates the drain hole below the evaporator coils. You will have to melt the ice in the drain hole and flush it out with hot water.
I hope this helps you. Please let me know if I can assist you further.
Vic
Anonymous
  • Posted on Oct 15, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
How do I reset the freezer on my LG refrig? It is set at -3 now
Follow the steps on the picture
Also... if you would like... here is a complete manual for your model.
http://www.lg.com/us/support-product/lg-LFX25974SW#
2answers
Why does freezer light not come on when freezer and fridge are working
You need to replace the light or check and make sure your switch is not frozen and being held in
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
2helpful
Lights go off and on
your sensor sw is deff call for a tech to replaced
LG LFC23760SB Refrigerator doesn't have power. The outlet is ok. Didn't have a power surge.
i think there is problem with your compressor unit. You need some maintanance or service of your refrigerator at regular period.
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Door left open it turned off - how do I turn it back on
?? you left it open??? and now the lights arent workin is that correct??
if this is the case, no worry, the lights should havea built in thermosat that turn them off iff too hot( door left open) give it 20-30 min the lights will cool down and come back on.. its meant to do that soit doesnt coo yor food if the light switch ever fails
I opened my fridge to get something out, shut the door and EVERYTHING WENT OUT??? No lights, no nothing??? I tripped the breaker and checked the cord etc... Nothing????
Make sure your getting power at the outlet by pluging in somthing like a hair dryer. If your getting power at your outlet then you probably have a controlboard problem.
If you don't have power then first look for GFI RESET in the kitchen. or fuse box.
2answers
Freezer light no longer comes on. LG LFX28977 3 door refrigerator with Bottom drawer freezer.
The switch and or the led light assy has ice inside of it. This is a known issue with this LG unit.
Call LG and request them to fix this under a warrranty.
Good luck.
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
