My dehumidifier stopped collecting water. Everything else seems to work, there is just no water extraction.
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
SOURCE: LG LD65EL dehumidifier will not collect water
Make sure the filter is clean and also make sure the coils are cleaned. If these are clogged they will restrict airflow which will cause the coils not to remove the humidity from the air. LG recommends that you clean the air filter every 2 weeks. They also include a brush to clean the coils. If this still does not work you will need to contact LG for service or a replacement. They have a 5 year warranty on them so the ones that you guys have should still be under warranty. Make sure that you have your reciept when you contact them to prove that it is still under warranty. Keep me posted. Also please rate my solution when you get a chance. Thanks - Tech101
SOURCE: dehumidifier runs without collecting water
1- check if the water collecting bucket is properly installed (the light will show is ON but if the bucket is not propely installed -pushed in the proper position ) -make sure the slots on the bottom of the dehumidifier are posisioned correctly.
SOURCE: LG dehumidifiers
It is defective. The coils are not getting cold enough to condense water in the air. If you have the receipt and the unit is less than 5 years old, give LG a call for warranty repair.
SOURCE: motor runs on dehumidifier but doesn't collect water
If it doesn't get cold change the temperature,
Put the float wire up.
finally it is out of r-14- freon.
Vitally
