Does anyone know what battery size goes in a Diesel Dz-4033 please?
SOURCE: instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
SOURCE: Just bought a new diesel dz 7069 watch and theres
Generally Diesel uses a pop off back. The pop off
back will be smooth and have no indication of how to come off.
To remove a pop off back use a watch knife
and press it straight into the separation between the case and back. Start at the upper right corner. Do
not use a sharp knife or widdle back and forth as this may damage the
surface where the seal is or make burrs. Once you have driven the knife
straight in you can move around the back repeating this until the back
is completely off.
SOURCE: Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
SOURCE: my diesel watch gets reset everyday dz-7044110703
I have the exact same problem. The watch was working fine up until I had the battery replaced. I went to another watch repair shop (couldn't go to the same one as I had moved to another town) and the chap there explained that with Diesel watches, when the batteries are replaced a small button inside the mechanism must be pressed to reset the settings, if this isn't done then the annoying problem, inflicting our watches, will occur.
My watch worked fine after, for a few days, then it began to reset again; casting doubt on the watch repair man's explanation. I'll go back to see the chap when I have the time, prob next week and keep you chaps posted on anything new.
