SOURCE: nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
SOURCE: After full battery drain, no function
Hello FixYa,
How I solved the problem ???
Read my former post again.
I thought this could help you with your troubleshoot database.
Ragards, Marc
SOURCE: Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
SOURCE: Hi-cant get the back off my M&S watch to change battery?
The slots are intended for a special tool.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
SOURCE: I have a garmin watch
Thanks for contacting FIxYa.
Unfortunately, that is an issue that you will have to contact Garmin with. Its a bit more complicated then a typical watch repair. You can contact them here:
http://www.garmin.com/garmin/cms/home/support/supportcontact
Best regards. Jewel
