SOURCE: Tone arm won't drop
This is a tough one. There is usually a series of gears that function in unison to make all the magic happens. These gears are usually set in motion by a smaller belt located inside the unit. If this belt has come off or is damaged, your unit will not work. Or, if the gears have cracked, or dried up, same issue.
Suggest taking it to a service center for repair.
- OPTiC
Turntable Technician
www.1200s.com
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
SOURCE: Numark TTX tonearm base repair
Unfortunately, the only way to access the tonearm is through the bottom. It's not that difficult, but you should be very careful when placing your turntable upside down to remove the base.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
SOURCE: SL-1200 MK2 Tone Arm Oxidized and Height Adjust
next time your height adjustment ring gets stuck dont bang on it or spray wd-40 anywhere near your gear, that will ruin things like you wouldent beleive. This happens to every 1200 and its perfectly normal, all you do is wiggle the lock lever on and off a few times until it frees itself gently.
and imo a new tone arm is a wise choice, shops charge around 50-60$ to fix it, and 70$ for the part i beleive. Once the tone arm is buggered there is little point in trying to fix it, replacement is inevitable.
Good luck
SOURCE: tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
