I believe the model is : FS-C2126MFP
To Repair (Error Code 1102 Kyocera) error you need to follow these steps:
Step 1:
Download the (Error Code 1102 Kyocera) Repair Tool
http://www.almuseo.com/download-repair?Error%20Code%201102%20Kyocera
Step 2:
Click on the "Scan Now" link
Step 3:
Then click on 'Fix'. The Fix is complete.
*File size: 1MB
Download time: <45 Secs
SOURCE: what is Error Code 1102
If you get errors after refilling and then you clear the error!
And you still get errors occuring then this is a problem with the
cartridge.
1)The cartridges printhead may have burned out if it was run dry. (new cartridge is required)
2) No ink is coming out of the port hole! Try dabbing the bottom of the
cartridge on tissue. Ink should appear if not then use tissue with
Isopropyl alcohol and blot lightly until ink apppears.
3) If not ink appears then you may have an air bubble blocking the flow
of the ink. wrap cartridge tightly in plastic wrap holing in an up
right position whip downwards this will force air to the top of the
cartridge and open the port on the bottom. Remove wrap and try it out.
4) If the cartridge sat empty for a period of time before refilling you
are wasting your time. The ink is probably sitting at the top of the
cartridge and can not migrate to the bottom, in this case it may have
burned out.
In refilling of Lexmark cartridges:
Refill often and do not allow them to run dry. Running them while there
is not ink in the cartridge burns the print head out and the cartridge
will not work and you will get an error.
By refilling often the cartridge stays in good condition, you do not
run out of ink during a print job, and the cartridge will have a
prolonged life span.
SOURCE: code error 1102
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
